[postgis-users] Re: PG 8.0 and PostGIS 1.0 RC1onWindows2003overlap
Randy George
rkgeorge at cadmaps.com
Thu Jan 27 09:12:49 PST 2005
Hi
I just installed PG 8.0 and PostGIS 1.0 RC2 on a Windows 2003
server
When attempting the old query on my test data:
select id, type as name, AsText(the_geom) from ibus where type='SOR' and
the_geom && transform(GeometryFromText('BOX3D(284519.3
3769952.1,496251.69999999995 3596407.1)'::box3d,26712),4269);
I get: ERROR: function geometryfromtext(box3d, integer) does not exist
Replacing Box3D with LineString:
the_geom && transform(GeometryFromText('LineString(284519.3
3769952.1,496251.69999999995 3596407.1)',26712),4269);
Since the bounding box is the same as the BOX3D but Linestring is a text
this gives the correct result.
I was looking through the docs for some more information on Box3D but I'm
not clear when/how use of Box3D would be appropriate?
Is 'BOX3D(284519.3 3769952.1,496251.69999999995 3596407.1)'::box3d a
shortcut for creating a bounding box geometry only when SRID is not an
issue? Or is there a way to transform a Box3D to a new SRID?
It is used in the examples Re: 4.6.1 in new docs
Thanks
randy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, January 25, 2005 3:04 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Re: PG 8.0 and PostGIS 1.0
Hi strk,
> Behalf Of strk at refractions.net
> Sent: 25 January 2005 09:25
> To: Mark Cave-Ayland
> Cc: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] Re: PG 8.0 and PostGIS 1.0
> Mmm.. I wouldn't use GeometryFromText with a BOX3D argument.
> I think it should only accept 'text' as it has been done with
> GeomFromWKB only accepting bytea.
No complaints here. We do a lot of queries like "the_geom && BOX3D('1 2 3, 4
5 6')" (and I believe the Mapserver connector uses a similar query) so as
long as these still work, I can live without accepting BOX3D as part of
GeometryFromText().
> Beside this, you can use asEWKT(geometry) to see Extended WKT.
That's the function I couldn't remember then :)
> .. And .. I've found the bug.
> The transform() functoin is failing to transform/recompute an
> already cached bbox.
> I'm working on it.
Just got your patch, but having Windows/Linux conversion problems ;) Will
try and find a moment to test it at this end later.....
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
