[postgis-users] polygonize and other geometry constructors
strk at refractions.net
Fri Jan 28 08:14:10 PST 2005
On Fri, Jan 28, 2005 at 10:00:02AM -0600, Pericles S. Nacionales wrote:
> Hi, I'm trying to make polygons out of point geometries and have a couple of
> questions:
> 1. Does polygonize work on point geometries or just on lines?
Should work with every geometry with dimension > 0 (all but points).
> 2. How does the MakeLine and LineFromMultiPoint work? I tried both on my
> point geoms and both returns:
> ERROR: function linefrommultipoint(geometry) does not exist
> HINT: No function matches the given name and argument types. You may need to
> add explicit type casts.
Did you feed the lwpostgis.sql script to your database ?
Or are you using some custom upgrade method ?
The calls are correct.
--strk;
> I have PostGIS 1.0rc2 compiled with GEOS 2.1.1. I can use the Collect
> function to create mulipoint geoms from point geoms but the other functions
> don't work for me. What am I doing wrong?
> Here's are the statements I used for #2:
> SELECT makeline(the_geom) FROM data WHERE squirrelid=702
> SELECT linefrommultipoint(collect(the_geom)) FROM data WHERE squirrelid=702
> While I'm at it, I might as well ask if there are any wildlife/population
> ecology types out there who use PostGIS? And if so, have you used PostGIS to
> do homerange analysis stuff?
> Thanks,
> Perry Nacionales
> Dept. of Ecology, Evolution, and Behavior
> University of Minnesota
> work: 612 624 6713
> e-mail: nacional at cbs.umn.edu
> postgis-users mailing list
