[postgis-users] BC Albers Projection In Spatial Ref Sys Table?
Paul Ramsey
pramsey at refractions.net
Fri Jan 28 08:38:34 PST 2005
3005 is the new, official, EPSG code, as assigned by EPSG itself.
42102 is the made-up number that CubeWerx invented for NFIS.
3005 is quite new, so you will still find lots of references to 42102
hanging around.
P
On Friday, January 28, 2005, at 07:38 AM, John Fletcher wrote:
> Darren,
> Thanks - that's a little embarassing, I should have just done that
> first. I was looking exclusively for EPSG:42102 - I didn't think of
> looking elsewhere.
> John
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net on behalf of
> Darren Houston
> Sent: Fri 1/28/2005 3:07 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] BC Albers Projection In Spatial Ref Sys
> Table?
> Hi John,
> I am using a PostGIS CVS version from a month or so ago, and I checked
> for BC
> Albers. In my spatial_ref_sys table, it resides at srid=3005
> This query returned the result;
> select * from spatial_ref_sys where srtext like '%BC%'
> Hope this helps,
> Darren H.
> On January 27, 2005 10:11 pm, John Fletcher wrote:
> > I can't seem to find BC Albers in the spatial_ref_sys.sql. Should
> > this projection be added manually, is it under a different ID than
> > EPSG:42102, or did I just miss it? I'm using v1rc1, but checked rc2
> > also.
> > Thanks a bunch.
> > John
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
