[postgis-users] Patch for PostGIS CVS on Windows
Jean David TECHER
davidtecher at yahoo.fr
Fri Jul 1 04:35:46 PDT 2005
In postgis/Makefile.config.in
if I let
USE_ICONV=@USE_ICONV@
when I did
rm -f postgis.log; make clean && make distclean; configure 2>&1 >> postgis.log; make 2>&1 | tee -a postgis.log
here is the problem I got reported from postgis.log
checking for gcc... gcc
checking for C compiler default output... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking for pg_config... /c/PostgreSQL/8.0.3/bin/pg_config
checking which template to use... win32
checking for geos-config... /c/PostgreSQL/8.0.3/bin/geos-config
checking for proj... /c/PostgreSQL/8.0.3/bin/proj
checking for flex... /mingw/bin/flex
checking for yacc... /mingw/bin/yacc
checking for install... /bin/install
configure: creating ./config.status
config.status: creating Makefile.config
SUMMARY
HOST_OS: mingw32
PGSQL: /c/PostgreSQL/8.0.3/bin/pg_config
GEOS: /c/PostgreSQL/8.0.3/bin/geos-config
PROJ: dir=/c/PostgreSQL/8.0.3/bin/..
PORTNAME: win32
PREFIX: /usr/local
EPREFIX: ${prefix}
DOC: ${prefix}/share/doc
DATA: ${prefix}/share/postgresql/contrib
MAN: ${prefix}/man
BIN: c:/PostgreSQL/8.0.3/bin
EXT: c:/PostgreSQL/8.0.3/lib (\$$libdir)
make -C lwgeom
make[1]: Entering directory `/home/david/sources/PostGIS/cvs/postgis/lwgeom'
sh ../geos_version.sh /c/PostgreSQL/8.0.3 > postgis_geos_version.h
cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e 's:@MODULE_FILENAME@:\$libdir/liblwgeom.1.1.dll:g;s:@POSTGIS_VERSION@:1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.1:g;s/@POSTGIS_BUILD_DATE@/2005-07-01 11:32:40/g' | grep -v '^#' > lwpostgis.sql
cp lwpostgis.sql ..
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o measures.o measures.c
measures.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o box2d.o box2d.c
box2d.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o ptarray.o ptarray.c
ptarray.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_api.o lwgeom_api.c
lwgeom_api.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom.o lwgeom.c
lwgeom.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoint.o lwpoint.c
lwpoint.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwline.o lwline.c
lwline.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoly.o lwpoly.c
lwpoly.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoint.o lwmpoint.c
lwmpoint.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmline.o lwmline.c
lwmline.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoly.o lwmpoly.c
lwmpoly.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwcollection.o lwcollection.c
lwcollection.c:1: warning: -fPIC ignored for target (all code is position independent)
g++ -I/c/PostgreSQL/8.0.3/include -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
lwgeom_geos_wrapper.cpp:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktunparse.o wktunparse.c
wktunparse.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgparse.o lwgparse.c
lwgparse.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktparse.tab.o wktparse.tab.c
wktparse.tab.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lex.yy.o lex.yy.c
lex.yy.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o vsprintf.o vsprintf.c
vsprintf.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o liblwgeom.o liblwgeom.c
liblwgeom.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_pg.o lwgeom_pg.c
lwgeom_pg.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_debug.o lwgeom_debug.c
lwgeom_debug.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_spheroid.o lwgeom_spheroid.c
lwgeom_spheroid.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_ogc.o lwgeom_ogc.c
lwgeom_ogc.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
lwgeom_functions_analytic.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos.o lwgeom_geos.c
lwgeom_geos.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_inout.o lwgeom_inout.c
lwgeom_inout.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_estimate.o lwgeom_estimate.c
lwgeom_estimate.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
lwgeom_functions_basic.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gist.o lwgeom_gist.c
lwgeom_gist.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_btree.o lwgeom_btree.c
lwgeom_btree.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_transform.o lwgeom_transform.c
lwgeom_transform.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o stringBuffer.o stringBuffer.c
stringBuffer.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box.o lwgeom_box.c
lwgeom_box.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box3d.o lwgeom_box3d.c
lwgeom_box3d.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
lwgeom_box2dfloat4.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_chip.o lwgeom_chip.c
lwgeom_chip.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_svg.o lwgeom_svg.c
lwgeom_svg.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gml.o lwgeom_gml.c
lwgeom_gml.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_triggers.o lwgeom_triggers.c
lwgeom_triggers.c:1: warning: -fPIC ignored for target (all code is position independent)
gcc -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-01 11:32:40"' -I/c/PostgreSQL/8.0.3/bin/../include -DUSE_PROJ -Ic:/PostgreSQL/8.0.3/include/server -Ic:/PostgreSQL/8.0.3/include/server/port/win32 -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_dump.o lwgeom_dump.c
lwgeom_dump.c:1: warning: -fPIC ignored for target (all code is position independent)
dlltool --export-all --output-def lwgeom.def measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o
dllwrap -o liblwgeom.1.1.dll --dllname liblwgeom.1.1.dll --def lwgeom.def measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o -lstdc++ -L/c/PostgreSQL/8.0.3/lib -lgeos -L/c/PostgreSQL/8.0.3/bin/../lib -lproj -Lc:/PostgreSQL/8.0.3/lib -lpostgres
Info: resolving _pj_errno by linking to __imp__pj_errno (auto-import)
Info: resolving _pj_release by linking to __imp__pj_release (auto-import)
dlltool --dllname liblwgeom.1.1.dll --def lwgeom.def --output-lib liblwgeom.a
make[1]: Leaving directory `/home/david/sources/PostGIS/cvs/postgis/lwgeom'
make -C loader
make[1]: Entering directory `/home/david/sources/PostGIS/cvs/postgis/loader'
gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80 -c -o shpopen.o shpopen.c
shpopen.c:176: warning: 'rcsid' defined but not used
gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80 -c -o dbfopen.o dbfopen.c
dbfopen.c:200: warning: 'rcsid' defined but not used
gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80 -c -o getopt.o getopt.c
gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80 -c -o shp2pgsql.o shp2pgsql.c
shp2pgsql.c: In function `utf8':
shp2pgsql.c:1628: warning: implicit declaration of function `bzero'
shp2pgsql.c:1631: warning: passing arg 2 of `libiconv' from incompatible pointer type
gcc -g -Wall -I.. -DUSE_ICONV -DUSE_VERSION=80 shpopen.o dbfopen.o getopt.o shp2pgsql.o -o shp2pgsql.exe
shp2pgsql.o(.text+0x2d7f): In function `utf8':
C:/msys/1.0/home/david/sources/PostGIS/cvs/postgis/loader/shp2pgsql.c:1613: undefined reference to `libiconv_open'
shp2pgsql.o(.text+0x2e29):C:/msys/1.0/home/david/sources/PostGIS/cvs/postgis/loader/shp2pgsql.c:1628: undefined reference to `bzero'
shp2pgsql.o(.text+0x2e56):C:/msys/1.0/home/david/sources/PostGIS/cvs/postgis/loader/shp2pgsql.c:1631: undefined reference to `libiconv'
shp2pgsql.o(.text+0x2e9a):C:/msys/1.0/home/david/sources/PostGIS/cvs/postgis/loader/shp2pgsql.c:1637: undefined reference to `libiconv_close'
collect2: ld returned 1 exit status
make[1]: *** [shp2pgsql.exe] Error 1
make[1]: Leaving directory `/home/david/sources/PostGIS/cvs/postgis/loader'
make: *** [loaderdumper] Error 2
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: PostGIS Users Discussion
Sent: Friday, July 01, 2005 11:29 AM
Subject: Re: [postgis-users] Patch for PostGIS CVS on Windows
On Fri, Jul 01, 2005 at 11:06:21AM +0200, Jean David TECHER wrote:
> I was not able to use iconv on MinGW for supoort utf-8 for shp2pgsql.
Can you report the problem ?
The configure script should be made able to cope with this.
--strk;
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050701/0912b0e2/attachment.html>
