[postgis-users] Status of geocoding functions in PostGIS?
Jeff Hoffmann jeff at propertykey.com
Sun Jul 3 13:59:21 PDT 2005
Alex Smith wrote:
> Did some searching of the archives and found this article stating that a
> geocoder for PostGIS is in the works (see
> http://postgis.refractions.net/pipermail/postgis-users/2004-September/005762.html).
> Just wondering the status of this project and if there is a time line
> for the release dates.
I don't know the status of this project, but here's a quick and dirty
alternative in the meantime:
- install the perl module "Geo::Coder::US" (either through CPAN or at
http://geocoder.us) & create a geocoder database from TIGER
- create language plperlu in the database you want the geocoder function
- create the following function, replacing "/path/to/geocoder.db" with
the location of the geocoder database you created from TIGER
CREATE OR REPLACE FUNCTION geocode(text) returns geometry as '
   use Geo::Coder::US;
   Geo::Coder::US->set_db("/path/to/geocoder.db");
   my @res = Geo::Coder::US->geocode($_[0]);
   return "SRID=4269;POINT(".$res[0]->{''long''}.
                         " ".$res[0]->{''lat''}.")";
' LANGUAGE plperlu IMMUTABLE;
Error checking (and all the rest of the fun stuff) is left as an
exercise for the reader.  That should be enough to get you started,
though.
Jeff Hoffmann
