[postgis-users] Using VIEW with MapServer is very slow
Niccolo Rigacci
niccolo at rigacci.org
Tue Jul 5 13:52:14 PDT 2005
Hi to all.
I'm at my first experiences with PostGIS, Mapserver and QGIS.
I had some trouble using a VIEW as a data source for MapServer or
QGIS; empirically I discovered that I had to include an OID field
into the VIEW to have it working.
I also added a record to geometry_columns by hand (with an
INSERT) instead of AddGeometryColumn():
CREATE VIEW wpt_comuni AS
SELECT istat_wpt.oid, istat_wpt.id,
istat_wpt.toponimo, residenti, wpt
FROM istat_comuni
JOIN istat_comuni2wpt
USING (idprovincia, idcomune)
JOIN istat_wpt
ON (idwpt = id);
INSERT INTO geometry_columns
VALUES('', 'public', 'wpt_comuni', 'wpt', 2, 4326, 'POINT');
Please, can someone confirm that this make sense?
But the real problem is that the query on the VIEW is very slow!
Using debug from Postgres I see that the query is:
BEGIN;
DECLARE mycursor BINARY CURSOR FOR
SELECT
toponimo::text,
asbinary(force_collection(force_2d(wpt)),'NDR'),
OID::text
FROM wpt_comuni
WHERE (residenti > 20000)
AND (
wpt &&
setSRID('BOX3D(4.83 36,20.16 47.5)'::BOX3D,
find_srid('','wpt_comuni','wpt'))
FETCH ALL IN mycursor;
The query is extremely slow from the command line too (2 min).
But if I do only the SELECT (without using the CURSOR), the
answer is near immediate.
The CURSOR is executed immediately instead if I omit the AND
clause (the overlap check between points and the BOX3D).
Should I have to create some INDEXes? Are VIEWs not suitables for
MapServer? Any hints will be apreciated!
Niccolo Rigacci
Firenze - Italy
War against Iraq? Not in my name!
