[postgis-users] Using VIEW with MapServer is very slow
Paul Ramsey
pramsey at refractions.net
Thu Jul 7 12:10:29 PDT 2005
Mapserver and QGIS both use binary cursors for performance, and you
can only get a binary cursor by DECLARING it. So they DECLARE then
they FETCH ALL (I thought Mapserver fetched in smaller blocks though,
to keep it from getting too memory-large when running large maps).
I am not sure what the correct compromise is to get optimal performance.
P.
On 7-Jul-05, at 3:17 AM, Niccolo Rigacci wrote:
>> But the real problem is that the query on the VIEW is very slow!
>> Using debug from Postgres I see that the query is:
>> BEGIN;
>> DECLARE mycursor BINARY CURSOR FOR
>> SELECT
>> FETCH ALL IN mycursor;
>> The query is extremely slow from the command line too (2 min).
>> But if I do only the SELECT (without using the CURSOR), the
>> answer is near immediate.
> I got a feasible explanation from Richard Huxton, from the
> Postgres performance list:
>> So - if you ask for a cursor, PG weights things to give you the
>> first few rows as soon as possible, at the expense of fetching
>> *all* rows quickly. If you're only going to fetch e.g. the
>> first 20 rows this is exactly what you want. In your case,
>> since you're immediately issuing FETCH ALL, you're not really
>> using the cursor at all, but PG doesn't know that.
> I found that a workaround is to include an "ORDER BY" caluse in
> the VIEW definition, so the Postgres planner uses the same
> algorythm for the SELECT and the CURSOR.
> By the way, thare are some explanation on how MapServer and QGIS
> build their queries? Why they use a CURSOR just to FETCH ALL? Is
> there a way to influence this?
> Thanks again for your help.
> Niccolo Rigacci
> Firenze - Italy
> War against Iraq? Not in my name!
> postgis-users mailing list
