[postgis-users] Problem with &&-operator and transform()
Christian Schwartze
chris81 at minet.uni-jena.de
Mon Jul 11 04:57:50 PDT 2005
Hi to all PostGIS-users....
I have a table "earthquakes" with a GiSt-index on column "geo". I search for all earthquakes along a street using a buffer distance.
Does somebody know, why the GiST-index is not in use (as per explain), when combining the &&-operator with the transform()-function like in:
select quake_id, location, x(geo), y(geo)
from earthquakes
where geo && envelope(buffer(transform((select geo from roads where name = 'U.S. Hwy 85'),102009),5)) and within(geo,(select buffer(transform((select geo from roads where name = 'U.S. Hwy 85'),102009),5)));
Without the transform-function the query is very quick because of the GiST-index, but i need the transform-function to calculate in unit "meter".
Can somebody help me, thanks a lot!
Christian.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050711/339a1621/attachment.html>
