[postgis-users] bug in create_undef.sql
strk at refractions.net
Wed Jul 13 07:27:35 PDT 2005
Fixed, thanks.
--strk;
On Thu, Jul 07, 2005 at 03:19:42PM +0200, klaus Förster wrote:
> there's a bug in create_undef.pl for postgis version 1.0.2
> if you run it with the appropriate lwpostgis.sql and version 80,
> the resulting sql-code is invalid in the following line:
> DROP TYPE geometry_dump AS CASCADE;
> this is the result of a false regexp in create_undef.pl.
> using \w+ instead of [^(]+ should solve the problem
> klaus
> --- create_undef.pl 2005-07-07 14:49:02.000000000 +0200
> +++ fixed.pl 2005-07-07 14:48:55.000000000 +0200
> @@ -140,7 +140,7 @@
> foreach my $type (@types)
> - if ($type =~ /create type ([^(]+)/i )
> + if ($type =~ /create type (\w+)/i )
> if ( $version ge "73" )
> O-.
> /_ )
> | (U
> klaus* /|
> postgis-users mailing list
