[postgis-users] Re: Cluster Analysis
Eli Dylan Lorimer
e.d.lorimer at sms.ed.ac.uk
Sat Jul 16 09:06:18 PDT 2005
Hi Paul,
I think I'll try and go your suggested PL/R route. Is it true that I
can essentially send the results of a spatial query to R and invoke
*any* R function available on said data? I'm going to look into this
anyway and hopefully get it all to gel well with GeoTools such that I
can continue to make my requests over WFS.
As to your question about clusters on the fly, I like your idea of
having the static table that I update via trigger, but I really need
to dynamically pass a few parameters which will change the resulting
clusters. Hum, I'll put some more thought into this idea though as
that would be so much faster to do.
Cheers,
-dylan
Dylan,
Are you calculating clusters on the fly? Do you need to? How about
having a clusters table, that is hooked to your base data table with
a trigger? That will be just as up-to-date as your base data, and
only have to do the calculations once per data update.
Paul
PS. A distance threshold "cluster" will return lots of unexpected and
unwanted results, which is why more sophisticated tricks have been
developed.
