[postgis-users] Help, What am I missing gist_geometry_ops column???
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Jul 19 08:36:08 PDT 2005
Hi Steve, just leave out the comma before gist_geometry_ops
Jan
Stephen Woodbridge wrote:
> Hi all,
> I'm try to create a postGIS table in a schema and it is mostly working,
> but I am having trouble building an index.
> 1. loaded the postGIS extensions and spatial references into schema
> "public" like normal
> 2. created tables and loaded the data in my own schema like:
> ### Drop the table if it exists
> echo "DROP TABLE swoodbridge.rgeo;" | psql -U pgsql -h localhost dev
> ### Define the table so we can load data into it
> FILE=`ls e*/*.shp | head -1`
> shp2pgsql -p -s 4326 -g the_geom $FILE swoodbridge.rgeo | psql -U pgsql
> -h localhost dev
> ### Append each of the files to the table
> for FILE in e*/*.shp ; do
> shp2pgsql -a -s 4326 -g the_geom $FILE swoodbridge.rgeo | psql -U
> done
> The above all works and looks ok.
> 3. tried to create an index:
> dev=# create index rgeo_gidx on swoodbridge.rgeo using gist (the_geom,
> gist_geometry_ops);
> ERROR: column "gist_geometry_ops" does not exist
> I seem to have missed a critical step, but not sure what.
> Any help would be appreciated.
> -Steve
> postgis-users mailing list
