[postgis-users] Re: two different geometries with the same Astext
strk at refractions.net
Thu Jul 21 13:55:26 PDT 2005
On Thu, Jul 21, 2005 at 12:47:53PM -0300, Miguel de la Fuente wrote:
> Well, now we're getting to something.
> When I run
> -- SELECT postgis_full_version()
> I get
> POSTGIS="1.0.0RC3" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS DBPROC="0.2.0" RELPROC="0.2.0""
> So you're right, I'm using an old version wich has this bug not fixed.
> However, I run
> -- SELECT within(addbbox(dropbbox(g1)), addbbox(dropbbox(g2)))
> and it return TRUE
Mmm.. this doesn't confirm your problem is the box3d computation bug.
The addbbox(dropbbox()) call has the only effect of re-computing
the cached bounding box.
Are you sure about your tests ? I summarize them:
1) within: false
2) within(dropbbox): true
3) within(addbbox(dropbbox)): true
The above with exactly the same input data.
> Then I just must upsdate POSTGIS, and that would be the whole
> solution. doesn't it?
If you update to 1.0.3 a dump/reload would be required and
any dump/reload would recompute bounding boxes so you should
be ok.
> Thank you very much.
> One last thing, Could you tell me how to update the POSTGIS or why you
> asked me if I ever had an older version installed??
> Thanks a lot.
Upgrade process is described in postgis manual, online:
http://postgis.refractions.net/docs/ch02.html#upgrading
I asked about an older version installed because the old/bogus
version might have created corrupted bounding boxes which would
not be fixed by a simple (non dump/reloading) upgrade.
--strk;
> postgis-users mailing list
