[postgis-users] pgsql2shp segfault by multipolygon export
strk at refractions.net strk at refractions.net
Fri Jul 22 04:18:21 PDT 2005
Can you obtain a backtrace with gdb or a valgrind output ?
--strk;
On Fri, Jul 22, 2005 at 07:14:20PM +0800, ch.grau at uni.de wrote:
> hi all :-)
> i have build postgis-1.0.2 but multipolygon export still does not work.
> the error message
> ./pgsql2shp -f test.shp -P test -u test_user test_db test_table
> Initializing...
> Done (postgis major version: 0).
> Output shape: Polygon
> Dumping: XSegmentation fault
> kernel message:
> pgsql2shp[14742]: segfault at 0000000000000000 rip 0000000000408817
> rsp 0000007fbfffe670 error 6
> thanks for help
> christian grau
> >I suggest you download and build postgis-1.0.2
> >You should be able to use the pgsql2shp distributed with it
> >against older databases. If the problem persists please let us know.
> >--strk;
> >On Thu, Jul 21, 2005 at 07:56:50PM +0800, ch.grau at uni.de wrote:
> > hi all,
> > i have a problem while exporting an multipolygon layer with pgsql2shp.
> > exports of lines and points are ok
> > i'm using suse 9.2 / postgresql 8.0.2 and postgis-0.9.1 on 64bit
> > i get following error messeage
> > test:~ # /usr/local/pgsql/bin/pgsql2shp - f /var/pg_backup/shapes/test -P mutsave -u postgres test_db test_table
> > Initializing... Done.
> > thanks for help
> > christian grau
> > FreeMail und FreeSMS auf www.uni.de
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
