[postgis-users] pgsql2shp segfault by multipolygon export
strk at refractions.net
Fri Jul 22 07:11:54 PDT 2005
On Fri, Jul 22, 2005 at 10:04:23PM +0800, ch.grau at uni.de wrote:
> sorry ...
> yoop undefining USE_WKB works fine in postgis-0.9 version
> of pgsql2shp.c
Would you try applying the following patch to your source code ?
Undefining USE_WKB would not solve cases in which you extract
binary features (for example for mapserver).
--strk(patch_follows);
Index: postgis_inout.c
RCS file: /home/cvs/postgis/postgis/Attic/postgis_inout.c,v
retrieving revision 1.45
diff -U2 -r1.45 postgis_inout.c
--- postgis_inout.c 11 Aug 2004 17:07:26 -0000 1.45
+++ postgis_inout.c 22 Jul 2005 14:10:05 -0000
@@ -3873,5 +3873,5 @@
int getint(char *c)
- int i;
+ int i=0;
memcpy( &i, c, 4);
return i;
@@ -3881,5 +3881,5 @@
double getdouble(char *c)
- double d;
+ double d=0.0;
memcpy( &d, c, 8);
return d;
