[postgis-users] pgsql2shp segfault by multipolygon export
strk at refractions.net
Fri Jul 22 12:19:48 PDT 2005
Excellent, the bug was still in 1.0.2
Thank you for helping hunt them !
Nothing strange about 32bit correctness the bug
is a wrong assumption about size of an unqualified
int type (32bit assumed, while it is 64bit on 64bit
archs).
--strk;
On Fri, Jul 22, 2005 at 07:18:30PM +0200, Christian Grau wrote:
> i apply the patches and the exports now works :-)
> i tested the same shapes on a 64bit system with postgresql8.0.2 /
> postgis-1.0.2 / suse9.2
> there i get the same error message as on the system with postgresql8.0.2 /
> postgis-0.9.1 before i applyed the patches
> but strange: on a 32bit system with postgresql7.4 / postgis-0.9.1 there is
> no problem ?
> greetings
> christian grau
> -----Ursprungliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von
> Gesendet: Freitag, 22. Juli 2005 16:33
> An: postgis-users at postgis.refractions.net
> Betreff: Re: Re: [postgis-users] pgsql2shp segfault by multipolygon
> export
> Sorry, the following would also be needed.
> Previous patch was for GeomFromWKB.
> This one is for pgsql2shp
> Please let me know if this fixes your problems and we'd be releasing
> 0.9.2.
> --strk;
> Index: loader/pgsql2shp.c
> RCS file: /home/cvs/postgis/postgis/loader/pgsql2shp.c,v
> retrieving revision 1.53.2.4
> diff -U2 -r1.53.2.4 pgsql2shp.c
> --- loader/pgsql2shp.c 15 Dec 2004 08:53:52 -0000 1.53.2.4
> +++ loader/pgsql2shp.c 22 Jul 2005 14:31:49 -0000
> @@ -2965,5 +2965,5 @@
> uint32 popint(byte **c) {
> - uint32 i;
> + uint32 i=0;
> memcpy(&i, *c, 4);
> *c+=4;
> @@ -2972,5 +2972,5 @@
> uint32 getint(byte *c) {
> - uint32 i;
> + uint32 i=0;
> memcpy(&i, c, 4);
> return i;
> @@ -2982,5 +2982,5 @@
> double popdouble(byte **c) {
> - double d;
> + double d=0.0;
> memcpy(&d, *c, 8);
> *c+=8;
> postgis-users mailing list
