[postgis-users] Postgis Simplify
strk at refractions.net
Mon Jul 25 13:23:37 PDT 2005
On Mon, Jul 25, 2005 at 08:46:25PM +0200, Christo Du Preez wrote:
> Sorry for being stupid but if my data is in [lat/lon wgs84], what should
> I do to Simplify it as much as possible and also for the result to be in
> [lat/lon wgs84]?
You probably don't want to simplify "as much as possible", as that
would make all your geoms into points.
Being in lat/lon 0.1 might be a good starting point.
Increase or decrease after looking at output, which might
be ugly if you're simplifying a whole topology.
--strk;
> strk at refractions.net wrote:
> >On Mon, Jul 25, 2005 at 12:21:08AM -0700, Brent Wood wrote:
> >>I'm not sure why your data is output in exponential format, I haven't
> >>seen that
> >>before, maybe some format setting?
> >LWGEOM output uses %.15g as output format, which allows for
> >exponential form, it's not related to simplify().
> >--strk;
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
