[postgis-users] Odd problem with pgsql2shp
strk at refractions.net
Tue Jul 26 18:13:57 PDT 2005
Both your examples are returning non-zero result,
which means a failure. Are you on a 64bit machine ?
The dump seems to choke on second record, can you
try isolate that geometry into a single table
and see if dumping that small table works ?
--strk;
On Tue, Jul 26, 2005 at 05:47:53PM -0600, Ethan Alpert wrote:
> I'm running postgres 7.4.6 with postgis 0.9.0.
> I have a table that suddenly about a month ago started taking
> significantly more time to dump to a shapefile all of the sudden.
> I run vacuum analyze nightly on my database. This particular table has
> had a lot of data inserted into it when the problem started occurring
> but the number or records is only 16,156. The polygons are all 5 vertice
> rectangles. Suddenly it's taking nearly 20 minutes to dump to a shape.
> Meanwhile a table with over 500,000 records takes less than 4 minutes. I
> am at a complete loss to understand what about this particular table is
> causing the problem.
> I'd like to upgrade but this is a production system and I really don't
> want to take it down. I may have to if I can't come up with an
> explanation and fix for this problem.
> I can find no differences in how the two tables I'm dumping are defined
> with respect to indexes.
> Has anyone ever run into anything like this? Any idea what I can
> possibly try to do to fix this?
> -bash-2.05b$ /usr/bin/time pgsql2shp -u spatial spatialdb dems
> Initializing... Done.
> Dumping: X..X [16156 rows].
> Command exited with non-zero status 1
> 0.27user 0.35system 17:50.62elapsed 0%CPU (0avgtext+0avgdata
> 0maxresident)k
> 0inputs+0outputs (168major+490minor)pagefaults 0swaps
> -bash-2.05b$ /usr/bin/time pgsql2shp -u spatial spatialdb snaps
> Dumping: X..X [568961 rows].
> 12.62user 15.47system 3:42.43elapsed 12%CPU (0avgtext+0avgdata
> 0maxresident)k
> 0inputs+0outputs (168major+15637minor)pagefaults 0swaps
> postgis-users mailing list
