[postgis-users] Postgis Simplify
strk at refractions.net
Wed Jul 27 02:48:14 PDT 2005
Christo, you are using two different versions of postgis:
0.9.1 on Windows and 1.1.0CVS on Gentoo.
If you want to help you need to provide a self-contained
test script showing the problem.
BTW, note that 20 is a *really* big number for a tolerance
in lat/long space.
--strk;
On Wed, Jul 27, 2005 at 11:39:53AM +0200, Christo Du Preez wrote:
> No I don't have a test case, the result on the Windows platform just
> didn't look right to me.
> Windows:
> version: PostgreSQL 8.0.3 on i686-pc-mingw32, compiled by GCC gcc.exe
> (GCC) 3.4.2 (mingw-special)
> postgis_version: 0.9 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> postgis_lib_version: 0.9.1
> postgis_geos_version: 2.1.1
> postgis_proj_version: Rel. 4.4.9, 29 Oct 2004
> postgis_full_version: POSTGIS="0.9.1" GEOS="2.1.1" PROJ="Rel. 4.4.9,
> 29 Oct 2004" USE_STATS DBPROC="0.0.1" RELPROC="0.0.1"
> Gentoo:
> version: PostgreSQL 8.0.2 on i686-pc-linux-gnu, compiled by GCC gcc
> (GCC) 3.3.2 20031218 (Gentoo Linux 3.3.2-r5, propolice-3.3-7)
> postgis_version: 1.1 USE_GEOS=0 USE_PROJ=1 USE_STATS=1
> postgis_lib_version: 1.1.0CVS
> postgis_full_version: POSTGIS="1.1.0CVS" GEOS="2.1.1" PROJ="Rel.
> 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
> At first I recieved an "NOTICE: IllegalArgumentException: Exponent out
> of bounds" trying to run:
> SELECT
> AsSVG(intersection(Simplify(the_geom,20),GeometryFromText('POLYGON((16
> -38,33 -38,33 -21,16 -21,16 -38))',-1)),1,1) AS svg_geom
> FROM province
> WHERE the_geom && setSRID('BOX3D(16 -38, 33 -21)'::box3d,-1)
> It was the intersection() function that caused the error for whatever
> reason. Then I stripped the intersection() function and and noticed the
> exponential format of the results on windows (only on rows 3, 6 and 9),
> but the results on linux was lat/long wgs84. After further testing I
> noticed using npoints() that some rows on the windows machine didn't
> simplify as much as on the linux box. Again this was only on rows 3, 6
> and 9. As you can see below.
> windows:
> 1: 25290, 39
> 2: 23978, 43
> 3: 25999, 22046
> 4: 4996, 19
> 5: 24679, 31
> 6: 50819, 43120
> 7: 31899, 71
> 8: 63292, 45
> 9: 84990, 70460
> 10: 12878, 15
> 11: 1047, 8
> linux
> 1: 25290 39
> 2: 23978 43
> 3: 25999 41
> 4: 4996 19
> 5: 24679 31
> 6: 50819 25
> 7: 31899 71
> 8: 63292 45
> 9: 84990 59
> 10: 12878 15
> 11: 1047 8
> strk at refractions.net wrote:
> >Christo, please be specific about your problem.
> >Do you have a test case showing unexpected behaviour for
> >the simplify() function ?
> >Would you include postgis version information in the
> >file ?
> >--strk;
> >On Tue, Jul 26, 2005 at 09:27:44PM +0200, Christo Du Preez wrote:
> >>I used another installation, this time Linux and did the same test.
> >>This time the result was different on rows 3, 6 and 9. More what I was
> >>expecting in the first place.
> >>1: 25290 : 39
> >>2: 23978 : 43
> >>3: 25999 : 41
> >>4: 4996 : 19
> >>5: 24679 : 31
> >>6: 50819 : 25
> >>7: 31899 : 71
> >>8: 63292 : 45
> >>9: 84990 : 59
> >>10: 12878 : 15
> >>11: 1047 : 8
> >>In previous posts I also mentioned the exponential format that my result
> >>was, doing a Simplify(). I have also noticed that the exponential format
> >>was only on rows 3, 6 and 9. The rest of the results was lat/long wgs84,
> >>as expected.
> >>Can someone please shed some light on this?
> >>>Christo, nothing weird about it, not every shape contains redundand
> >>>informations.
> >>>Consider a straight line defined by millions of intermediate points.
> >>>A simplify(geom, 0) would make it a 2 point line.
> >>>If you google for Douglas-Peuker you'll get
> >>>lots of informations about the algorithm.
> >>>--strk;
> >>>On Mon, Jul 25, 2005 at 10:20:23PM +0200, Christo Du Preez wrote:
> >>>>This is really weird.
> >>>>select npoints(the_geom), npoints(Simplify(the_geom, .1))
> >>>>from province
> >>>>results to:
> >>>>1: 25290, 39
> >>>>2: 23978, 43
> >>>>3: 25999, 22046
> >>>>4: 4996, 19
> >>>>5: 24679, 31
> >>>>6: 50819, 43120
> >>>>7: 31899, 71
> >>>>8: 63292, 45
> >>>>9: 84990, 70460
> >>>>10: 12878, 15
> >>>>11: 1047, 8
> >>>>The data is lat/long wgs84, what could cause rows 3,6 and 9 not to
> >>>>simplify as much as the others?
> >>>>_______________________________________________
> >>>>postgis-users mailing list
> >>>>postgis-users at postgis.refractions.net
> >>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>Kind Regards,
> >>Christo Du Preez
> >>Senior Software Engineer
> >>Mecola IT
> >>http://www.mecola.com
> >>+27 [0]82 4255 895
> Kind Regards,
> Christo Du Preez
> Mecola IT
> +27 [0]82 4255 895
