Fwd: Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Gérald Fenoy
gfenoy at gmail.com
Thu Jul 28 07:27:27 PDT 2005
So we've finished to solve this problem.
But I would like to know if you use a new database or an old one ?
I also need to know if you would like to have all the utilities script
from postgis to be installed by the ebuild ? (create_undef.pl,
test_estimation.pl, postgis_proc_upgrade.pl, profile_intersects.pl,
test_joinestimation.pl) Indeed the ebuild don't install anyone of this
scripts but they may be needed by users.
And to finish with my questions, I would like to know if you would
like to have something which upgrade your old databases for you ?
For an example of what I could do for this auto-upgrade is like the db
initialisation into the postgresql ebuild. So if we choose to develop
this functionnality you need to use the command "ebuild
postgis-1.0.1_p20050727.ebuild config" to automaticaly upgrade your
old database. Maybe only a proc update may be needed .... must be
thinking.
Thanks in advance to answer me.
Cordially.
2005/7/28, Christo Du Preez <christo at mecola.com>:
> Hi Gérald,
> It's looking very good. Here is the result from the postgis_full_version():
> POSTGIS="1.1.0CVS" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.1" RELPROC="0.3.1"
> Also find attached the log generated from the emerge.
> Gérald Fenoy wrote:
> >Hi,
> >well now it's pretty near to be good :]
> >You need to reemerge the ebuild called : postgis-1.0.0_p20050727 cause
> >as you can see your log the old postgis-1.0.0_p20050524 ebuild don't
> >work with the lastest postgis-cvs tarball available on the refractions
> >web site. When you have emerged the postgis-1.0.0_p20050727 ebuild you
> >need to create a new database, then use the lwpostgis.sql and
> >spatial_ref.sql as mentioned at the end of the ebuild installation.
> >Then could you give me the result you obtain for the query "SELECT
> >postgis_full_version();".
> >Thanks in advance to anser.
> >Cordially.
> >2005/7/27, Christo Du Preez <christo at mecola.com>:
> >>Hi Gerald,
> >>Here is the log for postgis-1.0.0_p20050524. It doesn't look successful.
> >>Maybe it's because I did it in the after postgis-1.0.1_p20050727 and not
> >>before like you requested. Sorry about that.
> >>Let me know if there is anything else I can do.
> >>Regards,
> >>Christo
> >>Gérald Fenoy wrote:
> >>>Hi,
> >>>please could you log the whole compilation process with something like
> >>>this : emerge -v postgis >& emerge-postgis-1.0.0_p20050524.ebuild.log
> >>>This could help me more to see if there is a problem with an old
> >>>installation. Indeed I just try with the version 1.1.0CVS (2005-07-27
> >>>6:00) and I have a problem with the old ebuild so I made a new one for
> >>>the cvs version which is now called postgis-1.0.1_p20050727.ebuild and
> >>>you could get it from the web page gentoo.01map.net (or
> >>>http://www.01map.net/gentoo if the first one don't work). Indeed with
> >>>the postgis-cvs.tar.gz downloaded this morning from
> >>>postgis.refractions.net I have problem for the /usr/libexec directory
> >>>creation ...
> >>>So there are two solutions, first you choose to debug the first ebuild
> >>>then you send me the complete log requested before, second, you use
> >>>the fresh ebuild then you tell me if you have any problem with it (and
> >>>you could also inform me if it works like a charme ;) )
> >>>Waiting for a response.
> >>>Cordially.
> >>>ps: sorry for redondency.
> >>>----- Original Message -----
> >>>From: Christo Du Preez
> >>>To: Jean David TECHER
> >>>Sent: Wednesday, July 27, 2005 12:21 PM
> >>>Subject: Re: [postgis-users] Gentoo Emerge (from Gerald FENOY)
> >>>Hi there,
> >>>I have attached the complete emerge.log, I thought having all the info
> >>>might come in handy.
> >>>ebuild: postgis-1.0.0_p20050512.ebuild
> >>>Thanx in advance.
> >>>Jean David TECHER wrote:
> >>>>Hi,
> >>>>could you give me which is the version of the ebuild youve used to
> >>>>make this test ?
> >>>>Could you give me the emerge logs of this emerge ? (Indeed I would
> >>>>like to see if you don't have some trace of an old installation on
> >>>>your system, cause in that case portage will not remove the old
> >>>>one...)
> >>>>Cordially.
> >>>>PS: Sandro could U add gfenoy at gmail.com <mailto:gfenoy at gmail.com> as a
> >>>>sender for this mailling list, indeed he experiences a tecnical
> >>>>problem on his djayux.net mail server :/
> >>>> *From:* Christo Du Preez <mailto:christo at mecola.com>
> >>>> *To:* postgis-users at postgis.refractions.net
> >>>> <mailto:postgis-users at postgis.refractions.net>
> >>>> *Sent:* Tuesday, July 26, 2005 11:54 PM
> >>>> *Subject:* [postgis-users] Gentoo Emerge
> >>>> I Installed Postgis on Gentoo using:
> >>>> USE="geos proj doc" ACCEPT_KEYWORDS="~x86" emerge postgis
> >>>> select postgis_version() = 1.1 USE_GEOS=0 USE_PROJ=1 USE_STATS=1
> >>>> Does this mean it's still not using GEOS? If so what should I do
> >>>> to make it use GEOS?
> >>>_______________________________________________
> >>>postgis-users mailing list
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>Kind Regards,
> >>Christo Du Preez
> >>Senior Software Engineer
> >>Mecola IT
> >>http://www.mecola.com
> >>+27 [0]82 4255 895
> >>Calculating dependencies >>> Unpacking source...
> >>1.0.1_p20050727
> >>>>>Unpacking postgis-cvs-1.0.1_p20050727.tar.gz to /var/tmp/portage/postgis-1.0.1_p20050727/work
> >>>>>Source unpacked.
> >> * econf: updating postgis-cvs/config.guess with /usr/share/gnuconfig/config.guess
> >> * econf: updating postgis-cvs/config.sub with /usr/share/gnuconfig/config.sub
> >>./configure --prefix=/usr --host=i686-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --enable-autoconf --with-maxbackends=1024 --with-geos=/usr/bin/geos-config --with-proj=/usr
> >>configure: WARNING: If you wanted to set the --build type, don't use --host.
> >> If a cross compiler is detected then cross compile mode will be used.
> >>checking for i686-pc-linux-gnu-gcc... gcc
> >>checking for C compiler default output file name... a.out
> >>checking whether the C compiler works... yes
> >>checking whether we are cross compiling... no
> >>checking for suffix of executables...
> >>checking for suffix of object files... o
> >>checking whether we are using the GNU C compiler... yes
> >>checking whether gcc accepts -g... yes
> >>checking for gcc option to accept ANSI C... none needed
> >>checking for i686-pc-linux-gnu-g++... g++
> >>checking whether we are using the GNU C++ compiler... yes
> >>checking whether g++ accepts -g... yes
> >>checking whether ln -s works... yes
> >>checking for iconv_open in -lc... yes
> >>checking how to run the C preprocessor... gcc -E
> >>checking for egrep... grep -E
> >>checking for ANSI C header files... yes
> >>checking for sys/types.h... yes
> >>checking for sys/stat.h... yes
> >>checking for stdlib.h... yes
> >>checking for string.h... yes
> >>checking for memory.h... yes
> >>checking for strings.h... yes
> >>checking for inttypes.h... yes
> >>checking for stdint.h... yes
> >>checking for unistd.h... yes
> >>checking iconv.h usability... yes
> >>checking iconv.h presence... yes
> >>checking for iconv.h... yes
> >>checking build system type... i686-pc-linux-gnu
> >>checking host system type... i686-pc-linux-gnu
> >>checking for pg_config... /usr/bin/pg_config
> >>checking which template to use... linux
> >>checking for geos-config... /usr/bin/geos-config
> >>checking for proj... /usr/bin/proj
> >>checking for flex... /usr/bin/flex
> >>checking for yacc... /usr/bin/yacc
> >>checking for install... /bin/install
> >>configure: creating ./config.status
> >>config.status: creating Makefile.config
> >>config.status: creating config.h
> >> SUMMARY
> >> HOST_OS: linux-gnu
> >> PGSQL: /usr/bin/pg_config
> >> GEOS: /usr/bin/geos-config
> >> PROJ: dir=/usr
> >> ICONV: 1
> >> PORTNAME: linux
> >> PREFIX: /usr
> >> EPREFIX: ${prefix}
> >> DOC: ${prefix}/share/doc/postgis
> >> DATA: /usr/share/postgis
> >> MAN: /usr/share/man
> >> BIN: ${exec_prefix}/bin
> >> EXT: ${exec_prefix}/libexec (${exec_prefix}/libexec)
> >> [32;01m*[0m removing build directives for doc from Makefile
> >>make -C lwgeom
> >>make -C loader
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/loader'
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -c -o shpopen.o shpopen.c
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/lwgeom'
> >>sh ../geos_version.sh /usr > postgis_geos_version.h
> >>cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e 's:@MODULE_FILENAME@:/usr/libexec/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.1:g;s/@POSTGIS_BUILD_DATE@/2005-07-27 19:00:42/g' | grep -v '^#' > lwpostgis.sql
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o measures.o measures.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o box2d.o box2d.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o ptarray.o ptarray.c
> >>shpopen.c:176: warning: `rcsid' defined but not used
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -c -o dbfopen.o dbfopen.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_api.o lwgeom_api.c
> >>dbfopen.c:200: warning: `rcsid' defined but not used
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -c -o getopt.o getopt.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom.o lwgeom.c
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -c -o shp2pgsql.o shp2pgsql.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoint.o lwpoint.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwline.o lwline.c
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -I/usr/include -c pgsql2shp.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoly.o lwpoly.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoint.o lwmpoint.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmline.o lwmline.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoly.o lwmpoly.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwcollection.o lwcollection.c
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 -c -o PQunescapeBytea.o PQunescapeBytea.c
> >>g++ -O2 -march=pentium3 -fomit-frame-pointer -I/usr/include -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 shpopen.o dbfopen.o getopt.o shp2pgsql.o -o shp2pgsql
> >>gcc -g -Wall -I.. -O2 -march=pentium3 -fomit-frame-pointer -DUSE_ICONV -DUSE_VERSION=80 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o pgsql2shp.o -L/usr/lib -lpq -o pgsql2shp
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/loader'
> >>make -C utils
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/utils'
> >>chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl profile_intersects.pl test_estimation.pl test_joinestimation.pl
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/utils'
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktunparse.o wktunparse.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgparse.o lwgparse.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktparse.tab.o wktparse.tab.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lex.yy.o lex.yy.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o vsprintf.o vsprintf.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o liblwgeom.o liblwgeom.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_pg.o lwgeom_pg.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_debug.o lwgeom_debug.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_spheroid.o lwgeom_spheroid.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_ogc.o lwgeom_ogc.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos.o lwgeom_geos.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_inout.o lwgeom_inout.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_estimate.o lwgeom_estimate.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gist.o lwgeom_gist.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_btree.o lwgeom_btree.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_transform.o lwgeom_transform.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o stringBuffer.o stringBuffer.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box.o lwgeom_box.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box3d.o lwgeom_box3d.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_chip.o lwgeom_chip.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_svg.o lwgeom_svg.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gml.o lwgeom_gml.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_triggers.o lwgeom_triggers.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_dump.o lwgeom_dump.c
> >>cp lwpostgis.sql ..
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:00:42"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -shared -Wl,-soname,liblwgeom.so.1 measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o -shared -lstdc++ -L/usr/lib -lgeos -L/usr/lib -lproj -o liblwgeom.so.1.1
> >>rm -f liblwgeom.so.1
> >>ln -s liblwgeom.so.1.1 liblwgeom.so.1
> >>rm -f liblwgeom.so
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgis-cvs/lwgeom'
> >>>>>Test phase [not enabled]: dev-db/postgis-1.0.1_p20050727
> >>>>>Install postgis-1.0.1_p20050727 into /var/tmp/portage/postgis-1.0.1_p20050727/image/ category dev-db
> >>make -C lwgeom
> >>make -C loader
> >>make[1]: Nothing to be done for `all'.
> >>make -C utils
> >>make -C lwgeom install
> >>/bin/install -c -m 755 liblwgeom.so.1.1 /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/libexec/liblwgeom.so.1.1
> >>cd /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/libexec && \
> >>rm -f liblwgeom.so.1 && \
> >>rm -f liblwgeom.so && \
> >>/bin/install -c -m 644 lwpostgis.sql /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/share/lwpostgis.sql
> >>/bin/install -c -m 644 ../spatial_ref_sys.sql /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/share/spatial_ref_sys.sql
> >>make -C loader install
> >>/bin/install -c -m 755 pgsql2shp /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/bin/pgsql2shp
> >>/bin/install -c -m 755 shp2pgsql /var/tmp/portage/postgis-1.0.1_p20050727/image//usr/bin/shp2pgsql
> >>man:
> >>prepallstrip:
> >>strip: strip --strip-unneeded
> >> usr/bin/pgsql2shp
> >> usr/bin/shp2pgsql
> >>>>>Completed installing postgis-1.0.1_p20050727 into /var/tmp/portage/postgis-1.0.1_p20050727/image/
> >> [32;01m*[0m To create your first postgis database do the followings commands :
> >> [32;01m*[0m # su postgres
> >> [32;01m*[0m # createdb -E SQL_ASCII poolp
> >> [32;01m*[0m # createlang plpgsql poolp
> >> [32;01m*[0m # psql -d poolp -f /usr/share/postgresql/contrib/lwpostgis.sql
> >> [32;01m*[0m # psql -d poolp -f /usr/share/postgresql/contrib/spatial_ref_sys.sql
> >> [32;01m*[0m For more informations go to : http://postgis.refractions.net/documentation.php
> >> [32;01m*[0m (For french user only see http://techer.pascal.free.fr/postgis)
> >>>>>Regenerating /etc/ld.so.cache...
> >> [32;01m*[0m Caching service dependencies...
> >>[A[178G [34;01m[ [32;01mok[34;01m ][0m
> >>>>>Unpacking source...
> >>>>>Unpacking postgis-cvs.tar.gz to /var/tmp/portage/postgis-1.0.0_p20050524/work
> >>>>>Source unpacked.
> >> SUMMARY
> >> HOST_OS: linux-gnu
> >> PROJ: dir=/usr
> >> ICONV: 1
> >> PORTNAME: linux
> >> PREFIX: /usr
> >> EPREFIX: ${prefix}
> >> MAN: /usr/share/man
> >>make -C lwgeom
> >>make -C loader
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/loader'
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/lwgeom'
> >>cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e 's:@MODULE_FILENAME@:/usr/libexec/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.1:g;s/@POSTGIS_BUILD_DATE@/2005-07-27 19:02:07/g' | grep -v '^#' > lwpostgis.sql
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o measures.o measures.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o box2d.o box2d.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o ptarray.o ptarray.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_api.o lwgeom_api.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom.o lwgeom.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoint.o lwpoint.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwline.o lwline.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoly.o lwpoly.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoint.o lwmpoint.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmline.o lwmline.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoly.o lwmpoly.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwcollection.o lwcollection.c
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/loader'
> >>make -C utils
> >>make[1]: Entering directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/utils'
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/utils'
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktunparse.o wktunparse.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgparse.o lwgparse.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktparse.tab.o wktparse.tab.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lex.yy.o lex.yy.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o vsprintf.o vsprintf.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o liblwgeom.o liblwgeom.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_pg.o lwgeom_pg.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_debug.o lwgeom_debug.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_spheroid.o lwgeom_spheroid.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_ogc.o lwgeom_ogc.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos.o lwgeom_geos.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_inout.o lwgeom_inout.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_estimate.o lwgeom_estimate.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gist.o lwgeom_gist.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_btree.o lwgeom_btree.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_transform.o lwgeom_transform.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o stringBuffer.o stringBuffer.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box.o lwgeom_box.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box3d.o lwgeom_box3d.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_chip.o lwgeom_chip.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_svg.o lwgeom_svg.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gml.o lwgeom_gml.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_triggers.o lwgeom_triggers.c
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_dump.o lwgeom_dump.c
> >>cp lwpostgis.sql ..
> >>gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-27 19:02:07"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -shared -Wl,-soname,liblwgeom.so.1 measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o -shared -lstdc++ -L/usr/lib -lgeos -L/usr/lib -lproj -o liblwgeom.so.1.1
> >>rm -f liblwgeom.so
> >>make[1]: Leaving directory `/var/tmp/portage/postgis-1.0.0_p20050524/work/postgis-cvs/lwgeom'
> >>>>>Test phase [not enabled]: dev-db/postgis-1.0.0_p20050524
> >>>>>Install postgis-1.0.0_p20050524 into /var/tmp/portage/postgis-1.0.0_p20050524/image/ category dev-db
> >>make -C lwgeom
> >>make -C loader
> >>make -C utils
> >>/bin/install -c -m 755 liblwgeom.so.1.1 /var/tmp/portage/postgis-1.0.0_p20050524/image//usr/libexec/liblwgeom.so.1.1
> >>/bin/install: cannot create regular file `/var/tmp/portage/postgis-1.0.0_p20050524/image//usr/libexec/liblwgeom.so.1.1': No such file or directory
> >>make[1]: *** [install-lib-shared] Error 1
> >>make: *** [liblwgeom-install] Error 2
> >>!!! ERROR: dev-db/postgis-1.0.0_p20050524 failed.
> >>!!! Function einstall, Line 524, Exitcode 2
> >>!!! einstall failed
> >>!!! If you need support, post the topmost build error, NOT this status message.
> >> ...done!
> >>>>>emerge (1 of 2) dev-db/postgis-1.0.1_p20050727 to /
> >>>>>md5 files ;-) ChangeLog
> >>>>>md5 files ;-) metadata.xml
> >>>>>md5 files ;-) postgis-1.0.0_p20050512.ebuild
> >>>>>md5 files ;-) postgis-0.7.5-r2.ebuild
> >>>>>md5 files ;-) postgis-1.0.1_p20050727.ebuild
> >>>>>md5 files ;-) postgis-1.0.0_p20050524.ebuild
> >>>>>md5 files ;-) files/digest-postgis-1.0.1_p20050727
> >>>>>md5 files ;-) files/digest-postgis-0.7.5-r2
> >>>>>md5 files ;-) files/digest-postgis-1.0.0_p20050512
> >>>>>md5 files ;-) files/digest-postgis-1.0.0_p20050524
> >>>>>md5 src_uri ;-) postgis-cvs-1.0.1_p20050727.tar.gz
> >>>>>Merging dev-db/postgis-1.0.1_p20050727 to /
> >>--- /usr/
> >>--- /usr/libexec/
> >>>>>/usr/libexec/liblwgeom.so.1 -> liblwgeom.so.1.1
> >>>>>/usr/libexec/liblwgeom.so -> liblwgeom.so.1.1
> >>--- /usr/share/
> >>--- /usr/share/postgresql/
> >>--- /usr/share/postgresql/contrib/
> >>--- /usr/share/doc/
> >>--- /usr/share/doc/postgis-1.0.1_p20050727/
> >>>>>/usr/share/doc/postgis-1.0.1_p20050727/CHANGES.gz
> >>>>>/usr/share/doc/postgis-1.0.1_p20050727/COPYING.gz
> >>>>>/usr/share/doc/postgis-1.0.1_p20050727/CREDITS.gz
> >>>>>/usr/share/doc/postgis-1.0.1_p20050727/TODO.gz
> >>>>>/usr/share/doc/postgis-1.0.1_p20050727/README.postgis.gz
> >>--- /usr/bin/
> >>>>>/usr/bin/pgsql2shp
> >>>>>/usr/bin/shp2pgsql
> >>>>>Safely unmerging already-installed instance...
> >>--- !mtime obj /usr/share/postgresql/contrib/spatial_ref_sys.sql
> >>--- !mtime obj /usr/share/postgresql/contrib/lwpostgis.sql
> >>--- !mtime obj /usr/share/doc/postgis-1.0.1_p20050727/TODO.gz
> >>--- !mtime obj /usr/share/doc/postgis-1.0.1_p20050727/README.postgis.gz
> >>--- !mtime obj /usr/share/doc/postgis-1.0.1_p20050727/CREDITS.gz
> >>--- !mtime obj /usr/share/doc/postgis-1.0.1_p20050727/COPYING.gz
> >>--- !mtime obj /usr/share/doc/postgis-1.0.1_p20050727/CHANGES.gz
> >>--- !mtime obj /usr/libexec/liblwgeom.so.1.1
> >>--- !mtime obj /usr/bin/shp2pgsql
> >>--- !mtime obj /usr/bin/pgsql2shp
> >>--- !empty dir /usr/share/postgresql/contrib
> >>--- !empty dir /usr/share/doc/postgis-1.0.1_p20050727
> >>--- !empty dir /usr/libexec
> >>--- !empty dir /usr/bin
> >>--- !empty dir /usr
> >>--- !targe sym /usr/libexec/liblwgeom.so.1
> >>>>>original instance of package unmerged safely.
> >>>>>dev-db/postgis-1.0.1_p20050727 merged.
> >>>>>clean: No packages selected for removal.
> >>>>>emerge (2 of 2) dev-db/postgis-1.0.0_p20050524 to /
> >>>>>md5 src_uri ;-) postgis-cvs.tar.gz
> Kind Regards,
> Christo Du Preez
> Mecola IT
> +27 [0]82 4255 895
> 1.0.1_p20050727
> >>> Source unpacked.
> SUMMARY
> HOST_OS: linux-gnu
> PROJ: dir=/usr
> ICONV: 1
> PORTNAME: linux
> PREFIX: /usr
> EPREFIX: ${prefix}
> MAN: /usr/share/man
> make -C lwgeom
> make -C loader
> cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e 's:@MODULE_FILENAME@:/usr/libexec/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.3.1:g;s/@POSTGIS_BUILD_DATE@/2005-07-28 14:10:36/g' | grep -v '^#' > lwpostgis.sql
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o measures.o measures.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o box2d.o box2d.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o ptarray.o ptarray.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_api.o lwgeom_api.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom.o lwgeom.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoint.o lwpoint.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwline.o lwline.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwpoly.o lwpoly.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoint.o lwmpoint.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmline.o lwmline.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwmpoly.o lwmpoly.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwcollection.o lwcollection.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktunparse.o wktunparse.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgparse.o lwgparse.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o wktparse.tab.o wktparse.tab.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lex.yy.o lex.yy.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o vsprintf.o vsprintf.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o liblwgeom.o liblwgeom.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_pg.o lwgeom_pg.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_debug.o lwgeom_debug.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_spheroid.o lwgeom_spheroid.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_ogc.o lwgeom_ogc.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_analytic.o lwgeom_functions_analytic.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_geos.o lwgeom_geos.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_inout.o lwgeom_inout.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_estimate.o lwgeom_estimate.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_functions_basic.o lwgeom_functions_basic.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gist.o lwgeom_gist.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_btree.o lwgeom_btree.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_transform.o lwgeom_transform.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o stringBuffer.o stringBuffer.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box.o lwgeom_box.c
> make -C utils
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box3d.o lwgeom_box3d.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_chip.o lwgeom_chip.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_svg.o lwgeom_svg.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_gml.o lwgeom_gml.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_triggers.o lwgeom_triggers.c
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -c -o lwgeom_dump.o lwgeom_dump.c
> cp lwpostgis.sql ..
> gcc -O2 -march=pentium3 -fomit-frame-pointer -DUSE_VERSION=80 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"' -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"' -DPOSTGIS_BUILD_DATE='"2005-07-28 14:10:36"' -I/usr/include -DUSE_PROJ -I/usr/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -g -O2 -fPIC -fexceptions -DUSE_GEOS -shared -Wl,-soname,liblwgeom.so.1 measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwgeom_geos_wrapper.o wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_geos.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o -shared -lstdc++ -L/usr/lib -lgeos -L/usr/lib -lproj -o liblwgeom.so.1.1
> rm -f liblwgeom.so
> make -C lwgeom
> make -C loader
> make -C utils
> man:
> prepallstrip:
> usr/bin/pgsql2shp
> usr/bin/shp2pgsql
> ...done!
> >>> emerge (1 of 1) dev-db/postgis-1.0.1_p20050727 to /
> --- /usr/
> --- /usr/libexec/
> --- /usr/share/
> --- /usr/share/doc/
> --- /usr/bin/
> >>> /usr/bin/pgsql2shp
> >>> /usr/bin/shp2pgsql
> --- !empty dir /usr
> >>> Auto-cleaning packages ...
> >>> No outdated packages were found on your system.
> * GNU info directory index is up-to-date.
Gérald FENOY
01map.net
