Res: Re: [postgis-users] dropping geometry tables
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Jul 29 06:44:21 PDT 2005
Thank you, but:
dbpotgis-# DropGeometryTable('ezequias');
ERROR: syntax error at or near "DropGeometryTable" at character 1
dbpotgis=#
-------Mensagem original-------
De: Nicolas Ribot
Data: 07/29/05 10:19:35
Para: PostGIS Users Discussion
Assunto: Re: [postgis-users] dropping geometry tables
> I am sending a
> DROPGeometryTable(['dbpotgis'],ezequias);
> or
> DROPGeometryTable([dbpotgis],ezequias);
> or
> DROPGeometryTable('dbpotgis',ezequias);
> Where dbpotgis is the database name (schema)
> and ezequias is the name of my geometry table.
> The error reported in all cases is: ERROR: syntax error at or near
> DROPGeometryTable" at character 2
You have to quote schema name and table name:
select dropGeometryColumn('dbpotgis', 'ezequias');
(the brackets [] in the documentation indicate optional parameters for
a function. In this case, meanning you can use dropGemetryTable() with
only one parameter: the table name).
Nicolas
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050729/7995c029/attachment.html>
