Res: Re: [postgis-users] dropping geometry tables
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Fri Jul 29 06:46:02 PDT 2005
I forgot the word "select" on the statement. Sorry and thank you.
Ezequias
-------Mensagem original-------
De: Nicolas Ribot
Data: 07/29/05 10:19:35
Para: PostGIS Users Discussion
Assunto: Re: [postgis-users] dropping geometry tables
> I am sending a
>  DROPGeometryTable(['dbpotgis'],ezequias);
> or
>  DROPGeometryTable([dbpotgis],ezequias);
> or
>  DROPGeometryTable('dbpotgis',ezequias);
> Where dbpotgis is the database name (schema)
> and ezequias is the name of my geometry table.
> The error reported in all cases is: ERROR:  syntax error at or near
> DROPGeometryTable" at character 2
You have to quote schema name and table name:
select dropGeometryColumn('dbpotgis', 'ezequias');
(the brackets [] in the documentation indicate optional parameters for
a function. In this case, meanning you can use dropGemetryTable() with
only one parameter: the table name).
Nicolas
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050729/3eb56dcd/attachment.html>
