[postgis-users] How do you use PostGIS?
David Bitner osgis.lists at gmail.com
Mon May 2 09:10:37 PDT 2005
> > - Name of the organization
Metropolitan Airports Commission (Twin Cities, MN, USA Airport Authority)
> > - Data being managed in the database
Streets (w/address information)
Aircraft flight tracks
Complaint Locations
Noise Monitoring Towers
> > - How the data is being accessed / manipulated
Data is displayed using Mapserver with custom PL/PGSQL for different
types of aggregation.
PL/PGSQL based geocoder.
Web queries from Mapserver and geocoder based locations done through
PHP, javascript, and xmlhttp requests.
Airspace analysis for airport noise.
> > - Why you chose to use PostGIS for the application
Easy to develop with using PL/PGSQL
Easy interoperability with Mapserver
Price is right
Fast
Easy to manage
> > - What PostGIS feature or PostGIS-related software (not necessarily
> > internal to PostGIS) would make your life much easier/better?
Full 3-4 dimension support.
