[postgis-users] /usr/lib/pgsql/liblwgeom.so.1.0: undefined symbol: nth
Lars Luthman
larsl at users.sourceforge.net
Mon May 2 11:39:03 PDT 2005
On Mon, 2005-05-02 at 17:56 +0200, strk at refractions.net wrote:
> On Mon, May 02, 2005 at 12:15:01PM +0200, Lars Luthman wrote:
> > I have installed PostGIS 1.0 (using PostgreSQL 8.0.1, GEOS 2.1.1, and
> > PROJ 4.4.9). When I try to run 'psql -f lwpostgis.sql -d ll' I get the
> > following error message:
> > BEGIN
> > psql:/usr/share/pgsql/contrib/lwpostgis.sql:35: NOTICE: type
> > "histogram2d" is not yet defined
> > DETAIL: Creating a shell type definition.
> > psql:/usr/share/pgsql/contrib/lwpostgis.sql:35: ERROR: could not load
> > library
> > "/usr/lib/pgsql/liblwgeom.so.1.0": /usr/lib/pgsql/liblwgeom.so.1.0:
> > psql:/usr/share/pgsql/contrib/lwpostgis.sql:40: ERROR: current
> > transaction is aborted, commands ignored until end of transaction block
> > (lots and lots of lines similar to the last one)
> > createlang worked without problems. Any ideas?
> The symbol 'nth' is a postgresql symbol IIRC.
> Are you sure you run 'make clean' before building again
> postgis ? Was your postgis source tree configured against
> an older postgresql version ?
Yes, no. I tried building again without GEOS and that works.
Lars Luthman
PGP key: http://www.d.kth.se/~d00-llu/pgp_key.php
Fingerprint: FCA7 C790 19B9 322D EB7A E1B3 4371 4650 04C7 7E2E
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050502/3604358b/attachment.pgp>
