[postgis-users] Crosstab Queries
Darren Houston dhouston at beyondcompliance.ca
Mon May 2 13:50:10 PDT 2005
Hello Pericles,
There exists a utility called tablefunc, in the PostgreSQL source contrib
directory, which allows you to do crosstab queries. I never used it, because
I found it easier for me to create my simple crosstab type queries in sql,
but it may be worth looking at.
Darren H.
On May 2, 2005 01:53 pm, Pericles S. Nacionales wrote:
> > - Name of the organization
> University of Minnesota:
> 	1. Bell Museum/Department of Forest Resources
> 	2. Department of Ecology, Evolution, and Behavior
> > - Data being managed in the database
> 	1, Squirrel Project
> 		- Squirrel locations
> 	2. North American Pollen Database (NAPD) and European Pollen Database
> (EPD)
> > - How the data is being accessed / manipulated
> 	1. Data is displayed via MapServer (PHP/MapScript). Data entry via web
> interface.  Squirrel home range is calculated using ConvexHull function.
> 	2. The databases themselves were imported from the original pollen
> databases (in Paradox) available at NOAA's NCDC web site:
> http://www.ncdc.noaa.gov/paleo/pollen.html
> 	    Data is retrieved/viewed using MapServer.
> > - Why you chose to use PostGIS for the application
> 	1. For squirrel project:
> 		a. Needed PostGIS/GEOS functions like ConvexHull
> 		b. MapServer interoperability
> 		b. Low cost
> 	2. For pollen databases:
> 		a. Low cost
> 		b. MapServer interoperability (and I can view the pollen data much faster
> than viewing it in ArcView/ArcGIS).
> 		c. Because I wanted to use PostGIS
> > And also for our edification and strategic planning:
> > - What PostGIS feature or PostGIS-related software (not necessarily
> > internal to PostGIS) would make your life much easier/better?
> 		a. Additional functions useful for wildlife ecology (kinda like ESRI's
> Tracking Analyst extension or the animal movement extension)
> 		a. The 4D support is very exciting
> 		b. pivot-table/crosstab functions would be very cool (but this isn't
> necessarily spatial, I guess)
