[postgis-users] Question on GIST_GEOMETRY_OPS
strk at refractions.net strk at refractions.net
Wed May 4 00:41:33 PDT 2005
On Tue, May 03, 2005 at 06:32:45PM -0700, Lin Jianfong wrote:
> Hello,
> On section 4.5.1. GiST Indexes of PostGIS 1.0 Manual the syntax for building
> GiST index is described as follows:
> CREATE INDEX [indexname] ON [tablename]
>   USING GIST ( [geometryfield] GIST_GEOMETRY_OPS)
> What does GIST_GEOMETRY_OPS do?
It selects an operator class.
GiST is a general index, it requires an operator class definition
to know what to do exactly. Teoretically we could have more
than a single operator class which could be used for different
kind of accesses. Practically we have only that one.
It is defined as:
CREATE OPERATOR CLASS gist_geometry_ops
        DEFAULT FOR TYPE geometry USING gist AS ...
So I think omitting it in the CREATE INDEX command would be ok
it being the DEFAULT for GIST on geometry. Should be verified
with different pgsql versions.
--strk;
> Thanks.
> Hong
> postgis-users mailing list
