[postgis-users] Use of Postgis/postgresql without installation?
Guillaume Sueur
guillaume.sueur at geosignal.fr
Wed May 4 05:34:15 PDT 2005
Hi Andrea,
I've done that with the excellent DWebPro, which is free for
non-commercial use. You can run php, MySQL, Postgresql... It's amazing !
Postgis installation must be done manually, but it's quite easy.
The only restriction is that the data is copied locally to allow the
writing of postmaster.pid. If the database is huge, it can take a while.
We're working on the way to do the copy only once.
See http://www.dwebpro.com/ and ask me if any question.
Bye
Andreas Neumann wrote:
> Votre message a été scanné par InterScan VirusWall.
> Hi all,
> I have a question: is it possible to start and use postgresql/postgis
> from a read only cd-rom without first doing a setup? I am thinking about
> using postgis for a CD/DVD based mapping application but the goal is to
> run the application without a setup, directly from the DVD. Is that
> possible?
> Thanks for any pointer,
> Andreas
Guillaume SUEUR
GEOSIGNAL - Groupe BVA
25bis Avenue Marcel Dassault
31505 TOULOUSE CEDEX 5
