[postgis-users] How do you use PostGIS?
Carl Anderson
carl.anderson at vadose.org
Thu May 5 21:44:13 PDT 2005
Paul Ramsey wrote:
> If you could say in your response, at a minimum:
> - Name of the organization
Fulton County, Georgia
> - Data being managed in the database
primary version stored in PostGIS
Zoning, Parcels, Address Points, Landuse, Elevation Samples,
LRS and modelled addresses for streets, City Limits, Zip Code
Bdy, Sewer AM/FM, ....
version cached from another primary source
Geometry for streets, contours, impervious surface polygons,
Structure shapes, ....
specifically for streets the geometry is maintained in ESRI SDE to
make use of snapping and
topology constraints. Regular snapshots are made and address
ranges, zip codes, feature class,
and other support info is added in PostGIS due to the ease of SQL
scripting. The public
extracts for analysis are made from the completed product.
> - How the data is being accessed / manipulated
UMN Mapserver, Arcview 3.x, ArcGis 9.x, autodesk Mapguide,
autodesk Autocad, uDIG, JUMP, QGIS, ....
Backend queries for Permit Tracking. such as
based on a Parcel ID
is it within 50ft of a stream
is it inside a 100 yr floodplain
what are all of the zoning classes within the parcel
what city is it in
what inspection zon is it in
> - Why you chose to use PostGIS for the application
Ability to have a fine grained control over datasets. The
datasets work the way we want them to.
Ability to build custom data handling routines
Ability to build analytical datasets as mixtures of other datasets ie
strong use of views
scripted consruction of derivative datasets
automatically adding fire response left and fire
response right to each street segment for 911 extracts
adding zipcode and city code automatically
> And also for our edification and strategic planning:
> - What PostGIS feature or PostGIS-related software (not necessarily
> internal to PostGIS) would make your life much easier/better?
OLEDB OGISDataProvider support as a bolt on to pgoledb (Autocad,
ArcGIS, .... )
Coordinated support for functions that act on many tuples at one time
DGlib would be such and animal
as would Linear Referencing System Support
GPL'ed scripting contributions area on postgis.refractions.net
> Thanks so much!
> Paul
Thanks for the
