[postgis-users] GIS functions
Paul Ramsey pramsey at refractions.net
Fri May 6 07:26:00 PDT 2005
- Yes, the "selects" are redundant in this case.
- No, exteriorring() is a very clever trick, which turns your polygons
into the linestrings that represent their outer shells. The
intersection of a linestring and a linestring is a... point. Which is
exactly what you want.
You should find the solution provided works pretty darn well, very
clever stuff.
P
On 6-May-05, at 6:18 AM, Mark Fenbers wrote:
>>>  1) Given two point locations, I want to find the two intersecting
>>> points of
>>> the two 125km virtual circles that surround each point.
>> Hi Mark,
>> You could do something like:
>> Making a 125 km buffer around your points: you got polygons (postgis
>> polygonizes the circle).
>> Taking the exterior rings of these polygons: these are closed
>> linestring,
>> Intersects the two linestring to get the result. zero, one, two
>> points.
>> In SQL, it would be something like:
>> select astext(intersection(
>>  (select exteriorRing(buffer(pointFromText('POINT (93 95)'), 125,
>> 50))),
>>  (select exteriorRing(buffer(pointFromText('POINT (280 170)'), 125,
>> 50)))
>> Just make the intersection of the 2 polygons. If polygons don't touch,
>> the intersection will be empty, otherwise, the result will depend on
>> the shape of the 2 input polygons:
>> select asText(geomUnion(
>>   polygonFromText('POLYGON((1 1, 4 1, 3 5, 1 1))'),
>>   polygonFromText('POLYGON((1 3, 6 3, 1 7, 1 3))')
>  Mark
> <Mark.Fenbers.vcf>_______________________________________________
> postgis-users mailing list
