[postgis-users] How to reproject postgis layers in mapserver
Obe, Regina DND\MIS
robe.dnd at cityofboston.gov
Mon May 9 07:58:36 PDT 2005
I'm using mapserver 4.4.2 and PostGIS 8.0.2/1.0.0/proj 4.4.9. I have aerial
tiles of MrSID files in NAD 83 meters and my postgis layers in NAD 83 ft.
If I have my map in NAD 83 ft most works fine - I can zoom in out etc. and
its fairly fast. My aerial reprojects correctly to NAD 83 ft.
If I perform a query something like
qstring=parcel_id=blahblahblah&qlayer=parcels in my htm file
- then my aerial layer gets all screwed up - it doesn't seem to reproject
correctly. It takes a long time to run and then the whole aerial seems to
get squashed at the center of the zoomed in parcel. If I leave the aerial
out - the query works fine.
If I switch my map projection to NAD 83 meters, then the postgis layers
don't seem to reproject so they just don't show or show in very weird
places.
I'm assuming this is something wrong I'm doing with the postgis layers
because if I swap these with map info tab files or shape files of NAD 83 ft,
those seem to work fine and project if I put in a PROJECT END clause. I
tried putting in a PROJECT END .. in the postgis layers, but that didn't
seem to make a difference. I verified that my spatial fields are in the
geometry_columns table.
Below is a snippet of some of my mapfile
CONFIG PROJ_LIB "E:\DNDIntranet\mapserv\scripts\proj\"
CONFIG GDAL_DRIVER_PATH "E:\DNDIntranet\mapserv\scripts\fw\gdal_plugins\"
NAME REMSPROP
#meters EXTENT 225033.887 885954.489 245303.531 905462.069
EXTENT 738152.213543900 2907686.126484261 797440.9488538101
2970773.30444638
SIZE 500 500
SHAPEPATH "F:\Mapservdata"
UNITS feet
SYMBOLSET symbols/symbols35.sym
FONTSET symbols/fonts/font.lst
IMAGETYPE jpeg
TEMPLATEPATTERN "printable.html|loader.html|blankloader.htm"
PROJECTION
"init=epsg:2249"
#"init=epsg:26986"
END
LAYER
NAME "bosaerial2001"
STATUS DEFAULT
TILEINDEX "bostonsidtiles.shp"
TILEITEM "Location"
MINSCALE 300
MAXSCALE 5000
TYPE RASTER
PROJECTION
"init=epsg:26986"
END
PROCESSING "COLOR_MATCH_THRESHOLD=6"
PROCESSING "SCALE_1=0,255"
PROCESSING "SCALE_2=0,255"
PROCESSING "SCALE_3=0,255"
END
LAYER
NAME "neighborhoods"
CONNECTIONTYPE postgis
DATA "the_geom from neighborhoods"
CONNECTION "user=propuser dbname=dnddts host=localhost"
# PROJECTION
#AUTO
# "init=epsg:2249"
# END
TYPE POLYGON
STATUS default
CLASS
OUTLINECOLOR 30 0 0
END
END
LAYER
NAME "parcels"
DATA "the_geom from landparcels USING UNIQUE parcel_id"
STATUS DEFAULT
TYPE POLYGON
MAXSCALE 5000
CLASS
NAME "Parcel Footprint"
OUTLINECOLOR 100 100 200
LABEL
POSITION CL
SIZE MEDIUM
COLOR 0 150 0
END
END
TEMPLATE loader.html
END
