[postgis-users] Geomtry_columns may not have an oid
strk at refractions.net
Tue May 10 01:24:19 PDT 2005
On Mon, May 09, 2005 at 08:56:14PM -0400, Rod Taylor wrote:
> Don't pull an OID from Geometry_Columns when not necessary, since it may
> not have that system column (set default_with_oids to off).
> Patch attached for fix_geometry_columns().
The patch is not complete, geometry_columns.oid is also used
when fixing links to system tables. Since postgis creates that
table we might as well choose to be explicit about having oids,
what people think about it ?
--strk;
