[postgis-users] Spatial join optimisation
Bill Binko
bill at binko.net
Thu May 12 19:38:02 PDT 2005
On Fri, 13 May 2005, Rhys Ickeringill wrote:
> Hi List,
> I have two large tables I wish to spatially join - one which contains
> polygons, the other points of latitude and longitude. The join criteria is
> on polygons containing points.
> At present I have the query:
> SELECT pntid, polyid
> INTO PolygonsContainingPoints
> FROM Polygons INNER JOIN Points
> ON contains( Polygons.wkb_geometry, SetSRID( MakePoint(
> Points.longitude, Points.latitude ), 32767 ) )
As a non-PostGIS expert, but one who's had some success in this recently,
here's what I'd do:
A Quick and dirty way to make it use that index is this:
SELECT pntid, polyid INTO PolygonsContainingPoints FROM
Polygons JOIN Points ON contains(wkb_geometry,
SetSRID(MakePoint(longitude,latitude), 32767)) AND wkb_geometry ~
SetSRID(MakePoint(longitude, latitude), 32767));
The extra (superfluous) criteria should cause it to use the index.
However, I would really suggest something a bit more useful. Create a
column for the Points...
SELECT AddGeometryColumn('','Points','the_point_geom','32767','POINT',2);
update Points set the_point_geom = SetSRID(MakePoint(longitude,latitude),32767);
create index point_index on Points USING GIST (the_point_geom);
vacuum analyze Points;
select update_geometry_stats(); -- depending on your Postgresql version
Then you could write this:
select pntid, polyid into PolygonsContainingPoints FROM
Polygons JOIN Points on contains(wkb_geometry, the_point_geom) AND
wkb_geometry ~ the_point_geom;
This would use both index and result in a query measured in seconds, not
hours.
Bill
