[postgis-users] Spatial join optimisation
Richard_D_Levine at raytheon.com Richard_D_Levine at raytheon.com
Fri May 13 06:29:45 PDT 2005
If the reason you haven't created the points as geometries is because you
don't want to change your app to populate the column, you could place an
insert and update trigger on the table that populates an additional
geometry column from the lat/long.  I did this when I spatialized a legacy
app and it worked like a charm, though of course inserts slowed quite a
bit.
Cheers,
Rick
postgis-users-bounces at postgis.refractions.net wrote on 05/13/2005 12:45:27
AM:
> On Fri, 13 May 2005, Rhys Ickeringill wrote:
> > Thanks Paul, Bill.
> > HUGE speed improvement. According to the postgres ANALYSE command your
> > suggestions cut the estimated query cost by a factor of 1000 (!). My
query
> > hasn't finished yet - judging by how long it took to compute 100
records, my
> > estimate is one hour for the whole lot.
> I suppose I should have asked how many shapes you were working with...
> perhaps seconds was optimistic.  However, an hour still seems a long
time.
> I noticed below that you said that only one query was being used, even in
> the final solution.  Could you post the query plan (explain select....)
on
> that?
> If your "Points" sometimes lie outside ALL of the polygons in your
Polygon
> table, you can get another benefit by first calculating the extent() of
> your polygons and adding something like this to your query
> the_point_geom && setSRID('POLYGON((224941.15625 1192115.125,224941.15625
> 1396262.875,311462.8125 1396262.875,311462.8125 1192115.125,224941.15625
> 1192115.125))'::geometry, 26759)
> Of course, that's my extent, not yours.  That will leverage both of the
> indexes you have.
> to get the extent, you can just do something like
> select asText(extent(the_polygon_geom)) from Polygons;
> I'm considering creating an Extents table that contains the extents of my
> very static layers.  That way I could just join them in.
> > Bill, the difference between your "quick and dirty" approach and your
final
> > approach is a factor of two or so - purely due to there being no
geometry
> > index on the points, hence the sequential scan in the join goes to the
> > [larger] points table (and the polygon geometry index is used). If I
create
> > an index on the points table...
> > CREATE INDEX GeoIdx ON Points USING GIST( SetSRID( MakePoint(
> > Points.longitude, Points.latitude ), 32767 ) )
> > this index gets used and your "quick and dirty" approach runs perhaps
10%
> > slower than your final (and Paul's) approach - I guess this is the
overhead
> > of making points on the fly.
> It's also using Postgresql's functional indexes, which probably adds some
> overhead.  You're beter off adding a geometry column, and deleting the
> lat/long columns: you can always extract them from the shape if you need
> them.
> > Is it worth (for the benefit of the list) beginning a discussion on
what
> > "geometry operators" are best used with each "geometry processing
function",
> > with an eye to including a "tip" associated with each geometry
processing
> > function's entry in the PostGIS manual? (I'd be happy to do the
> > documentation changes)
> I think there is definitely a need for a "Tuning Guide".  The
> documentation mentions the fact that you need to use the operators for
> Postgresql to consider using indexes, but there are many other questions
> that could be explored such as:
> 1) When to extract non-spatial attributes and join on those instead
> 2) How to use Postgresql's partial indexes (ones with a WHERE clause)
> 3) How to use indexes with spatial and non-spatial attributes (is it
> possible?)
> 4) What are the relative costs (in terms of order of complexity) of
> the various operations
> I know much of this would be trial-and-error, but there needs to be a
> place for general guidelines.
> BTW, Rhys, you also should consider modifying the performance parameters
> in postgresql.conf as some of them make a huge difference
> (random_page_cost = 2 really helped me!).
> Bill
> postgis-users mailing list
