[postgis-users] good way to collect
strk at refractions.net strk at refractions.net
Mon May 16 10:35:31 PDT 2005
On Mon, May 16, 2005 at 09:38:26AM -0400, Purvis, Charlton wrote:
> Hi, folks:
> I thought doing a collect(the_geom) on a group of counties would produce a
> state-wide view of all the counties in one row.  The collect goes through
> fine, but it turns out to be a not isvalid(the_geom) result set.  The
> counties are each MULTIPOLYGON's from a shp2pgsql, and their the_geom's are
> all valid.
A collect of MULTIPOLYGONS should return a GEOMETRYCOLLECTION.
If all components are valid I think result should also be.
Try running isvalid on all rows and on result.
A false return should also raise a NOTICE about the specific
invalidity
--strk;
> Thanks for the help.
> Charlton
> postgis-users mailing list
