[postgis-users] GeomUnion to dissolve polygon borders
Matthew Perry
perrygeo at gmail.com
Mon May 16 21:47:45 PDT 2005
Hi folks,
I'm trying to use postgis to remove polygon borders between adjacent
polygons sharing a common attribute value (aka "dissolve" in the ESRI
world). Here was my first attempt:
CREATE TABLE landcover AS
SELECT GeomUnion(the_geom), covertype
FROM cveg
GROUP BY covertype
But it is SLOW... The query takes over 700 minutes. Just for
reference, ArcMap's dissolve tool takes about ~20 minutes for the
original shapefile on a comparable machine.
I have an index on each of the important fields:
CREATE INDEX cveg_geom_index ON cveg
USING GIST ( the_geom GIST_GEOMETRY_OPS );
CREATE INDEX cveg_covertype_index ON cveg (covertype);
VACUUM ANALYZE cveg;
Here's the EXPLAIN:
gisdata=> EXPLAIN SELECT GeomUnion(the_geom), covertype FROM cveg
GROUP BY covertype;
QUERY PLAN
HashAggregate (cost=6154.77..6154.79 rows=9 width=1212)
-> Seq Scan on cveg (cost=0.00..5917.18 rows=47518 width=1212)
(2 rows)
The shapefile in question only has 47518 polygon features (~50 MB for
the shp). Oh, and I'm running a 750 Mhz AMD with 128 MB RAM Linux
setup with Postgis 1.0/Postgres 8.0.2.
Is there anyway to speed this process up? Perhaps someone's worked out
a more efficient query to dissolve polygon borders?
Matt Perry
Humboldt State University
