[postgis-users] MakePoint/GeometryFromText core dump
Lars Holm Loldrup
LLO at CARLBRO.DK
Mon May 23 04:20:20 PDT 2005
I also get a core-dump with the following select:
SELECT GeometryFromText('POINT(-106 40.6666666666667)',-1);
Using the following configuration:
postgis_full_version
POSTGIS="1.0.0" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
This is the final PostGis 1.0.0 version on a RedHat 7.3 linux compiled with
gcc version 2.96.
ldd /usr/local/pgsql8/bin/postgres
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x4002c000)
libz.so.1 => /usr/lib/libz.so.1 (0x40070000)
libreadline.so.4 => /usr/lib/libreadline.so.4 (0x4007e000)
libtermcap.so.2 => /lib/libtermcap.so.2 (0x400a4000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x400a8000)
libresolv.so.2 => /lib/libresolv.so.2 (0x400d5000)
libnsl.so.1 => /lib/libnsl.so.1 (0x400e5000)
libdl.so.2 => /lib/libdl.so.2 (0x400fa000)
libm.so.6 => /lib/libm.so.6 (0x400fd000)
libc.so.6 => /lib/libc.so.6 (0x4011e000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
Will this problem be solved in the upcomming PostGis 1.0.1 version ?
Regards
Lars Holm Loldrup
Consultant
Carl Bro as, GIS&IT
Granskoven 8, DK 2600 Glostrup
Tlf.(dir): +45 4348 6466, Fax (dir): +45 4348 6810
mailto: <mailto:llo at carlbro.com> llo at carlbro.com
<http://www.carlbro.com> http://www.carlbro.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050523/d4bde89f/attachment.html>
