[postgis-users] Buffer() creates invalid polygons??
strk at refractions.net
Tue May 24 05:28:09 PDT 2005
What GEOS version ?
--strk;
On Tue, May 24, 2005 at 07:52:40AM -0400, Mark Fenbers wrote:
> I use the Buffer() function on a point to get a circular polygon
> (hereafter just called "circle"). I then later subtract away a
> rectangle (which partially overlaps the circle) using the Difference()
> function. This fails for about 20% (4 of 20) of the circles I compute.
> The error I get is:
> NOTICE: TopologyException: no outgoing dirEdge found
> (-103879.654,348793.58)
> ERROR: GEOS difference() threw an error
> I have found by accident that if I adjust the third argument to the
> Buffer() function, the error goes away for some circles, yet appears for
> others. For the 80% (16 of 20) of successes with the Difference()
> function, I used circles computed from "Buffer(the_geom, 231500.0,
> 90)". If I use 91 instead of 90, then I can get 2 or 3 (of the four
> that failed) to work without failing in the Difference() function, but
> then 2 or three others fail that had worked when the third Buffer() arg
> was set to 90.
> Eventually, I got all 20 of the circles to work using the Difference()
> function, but I had to run the query one circle at a time, and play with
> the value of Buffer()'s third arg until I found a value that worked for
> that particular circle. I shouldn't have to do this and suspect the
> problem is a bug. If needed, I can produce the SQL and the table
> containing the points.
> I am positive the problem is with the circles, and not the rectangles
> I'm subtracting from them, because when the Difference() function fails
> for a particular circle, it fails no matter what rectangle I use, and
> when I "fix" the circle by adjusting Buffer()'s third arg, it works for
> any rectangle I throw at it...
> Oh, I almost forgot to mention what the subject line refers to... Even
> when the Difference() function fails (and other functions like
> Intersection, GeomUnion, and SymDifference() fail also), the IsValid()
> function reports that the polygon *IS* a valid geometry. I've made sure
> that both the circle and the rectangle pass the IsValid() test before
> feeding them to the Difference() function, but for some circles,
> Difference() still fails. I don't mean to pick on the Difference()
> function as I think the problem exists in the Buffer() function
> instead. But I'll leave this for experts to determine...
> Mark
> postgis-users mailing list
