[postgis-users] Shp2pgsql load error
strk at refractions.net
Tue May 24 10:17:33 PDT 2005
A segfault from malloc ?! Never seen before...
And... doesn't happen w/out -W flag ?
Which architecture ?
Can you provide (the smallest) shapefile reproducing the bug ?
--strk;
On Tue, May 24, 2005 at 01:10:29PM -0400, Kralidis,Tom [Burlington] wrote:
> > -----Original Message-----
> > From: Kralidis,Tom [Burlington]
> > Sent: Tuesday, 24 May, 2005 13:09
> > To: 'PostGIS Users Discussion'
> > Subject: RE: [postgis-users] Shp2pgsql load error
> > > > Hi,
> > > > Thanks for the previous help on the encoding issues. When trying
> > > > again with the following command:
> > > > $ /usr/local/pgsql/bin/shp2pgsql -W ISO8859-1 -s 42304 wshed_p
> > > > public.wshed_p | /usr/local/pgsql/bin/psql -d devgeodb -U postgres
> > > > ERROR: unterminated quoted string at or near
> > "'SRID=42304;<SNIP_TONS_OF_GEOMETRY>64BA4041F6365E936DC3F8400151CD483F
> > > > BA
> > > > 404199B6A0E30AC4F8406EA" at character 158
> > > > LINE 1:
> > > > ...066.31678','281229.63625','485','01AM','Oromocto','SRID=4230...
> > > > Any suggestions?
> > > First of all redirect to a file instead of piping.
> > > Then run psql -f on that file, so the error will tell you
> > > line number causing it.
> > > Collapse your TONS of geometry and see what sound wrong in quoting.
> > I can't even get that far because shp2pgsql gives me back a
> > segfault when I want to redirect to file. So trying this in gdb:
> > $ gdb /usr/local/pgsql/bin/shp2pgsql
> > $ run -W ISO8859-1 -s 42304 wshed_p public.wshed_p
> > <SNIP>
> > INSERT INTO "public"."wshed_p"
> > ("area","perimeter","wshed_","wshed","shedname","the_geom")
> > VALUES
> > ('2127022066.31678','281229.63625','485','01AM','Oromocto','SR
> > ID=42304;<SNIP>
> > Program received signal SIGSEGV, Segmentation fault.
> > 0x00872f18 in _int_malloc () from /lib/tls/libc.so.6
> Whoops, forgot trace to shp2pgsql.c:
> #0 0x00872f18 in _int_malloc () from /lib/tls/libc.so.6
> #1 0x0087225d in malloc () from /lib/tls/libc.so.6
> #2 0x0804dc5a in safe_malloc (size=4) at shp2pgsql.c:130
> #3 0x0804ed41 in FindPolygons (obj=0x8a92a30, Out=0x1) at
> shp2pgsql.c:847
> #4 0x0804f12c in InsertPolygon () at shp2pgsql.c:997
> #5 0x0804e62b in LoadData () at shp2pgsql.c:640
> #6 0x0804e10c in main (ARGC=7, ARGV=0xbfe437f4) at shp2pgsql.c:401
> postgis-users mailing list
