[postgis-users] Rare circumstances crash pg
strk at refractions.net
Wed May 25 22:46:11 PDT 2005
On Wed, May 25, 2005 at 03:04:37PM -0500, Simpson wrote:
> Greetings,
> Using POSTGIS="1.0.0" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> DBPROC="0.3.0" RELPROC="0.3.0"
> On rare occasions the server crashes with combinations of spatial functions
> in the select and where.
> -- THIS WORKS
> select multi(Buffer(the_geom, 0)) from polygon where polyid = 6088;
> -- THIS CRASHES
> select multi(Buffer(the_geom, 0)) from polygon where not isvalid(the_geom)
> and polyid = 6088;
> I was going to package up a re-creatable scenario to include in this email,
> so I copied this row to a new table that I was going to dump and include,
> but upon creation of the new table, I could not get it to crash with above
> query. If I copy all the rows to the new table it crashes. Something to do
> with indexing?
Index should not be used in your query (check out explain output).
See if explain gives you different plans in the two cases.
Also, aren't you getting an exception buffering invalid geometries ?
Can it be you didn't compile postgresql with -lstdc++ (required
to cleanly handle C++ exceptions thrown by GEOS) ?
Finally, could you try out 2.1.2cvs version of GEOS (it's in branch-2-1
of GEOS cvs).
--strk;
> Below is the data from the_geom column if that helps.
> Thanks for any suggestions,
> Drew.
> select AsEWKT(the_geom) from polygon where polyid = 6088;
> asewkt
> SRID=4269;MULTIPOLYGON(((-80.402277 33.445738,-80.402687
> 33.445463,-80.402551 33.444936,-80.402414 33.444638,-80.402114
> 33.444318,-80.401895 33.444226,-80.401403 33.444203,-80.401321
> 33.444272,-80.400447 33.443057,-80.400447 33.442986,-80.400034
> 33.442461,-80.39988 33.442265,-80.40001 33.442163,-80.400065
> 33.441705,-80.400694 33.441087,-80.400694 33.44072,-80.40053
> 33.440537,-80.40053 33.440308,-80.400722 33.440056,-80.401214
> 33.439873,-80.401296 33.439758,-80.401296 33.439254,-80.401023
> 33.438796,-80.401132 33.437971,-80.401406 33.437857,-80.40157
> 33.437674,-80.401952 33.43749,-80.402226 33.437078,-80.402254
> 33.436162,-80.402363 33.436001,-80.402773 33.435772,-80.405096
> 33.435223,-80.405506 33.434971,-80.406899 33.434651,-80.407664
> 33.434307,-80.408293 33.433826,-80.40873 33.43362,-80.409359
> 33.433529,-80.410042 33.43385,-80.410233 33.434056,-80.410096
> 33.434331,-80.410123 33.43456,-80.410287 33.43472,-80.41097
> 33.434858,-80.411872 33.435454,-80.412145 33.435798,-80.412281
> 33.435866,-80.41242 33.436443,-80.412524 33.436661,-80.412705
> 33.436984,-80.412752 33.437145,-80.412892 33.438283,-80.412949
> 33.43842,-80.413019 33.438521,-80.412628 33.439014,-80.411404
> 33.438618,-80.408885 33.441616,-80.407139 33.443694,-80.404327
> 33.447043,-80.402468 33.446242,-80.402277 33.445738),(-80.405358
> 33.440444,-80.405158 33.440426,-80.405285 33.440615,-80.405358
> 33.440444),(-80.408047 33.43911,-80.406924 33.438408,-80.406658
> 33.438408,-80.405802 33.439605,-80.405685 33.439556,-80.405623
> 33.439725,-80.405718 33.439662,-80.405802 33.439605,-80.406994
> 33.440103,-80.408047 33.43911)))
> (1 row)
> postgis-users mailing list
