[postgis-users] problem with the postgisdriver-1.2.0 and JUMP1.2-Alpha1
Uwe Dalluege uwe.dalluege at rzcn.haw-hamburg.de
Thu May 26 05:34:52 PDT 2005
Hi
I have a problem with the postgisdriver-1.2.0
together with JUMP1.2-Alpha1
Problem:
When I do the following in JUMP ... (A)
1. Load Dataset(s)...    (from PostGIS)
2. Save Task As ...
3. Open Task ...
everything is all right :-)
But when I do the following in JUMP ... (B)
2. Save Dataset As ...   (back to the DataBase PostgreSQL)
3. Save Task As ...
4. Open Task ...
then I receive the error:
ERROR: syntax error at or near "null"
java.lang.IllegalStateException: ERROR: syntax error at or near "null"
 at
net.refractions.postgis.PostGISConnection.executeQuery(PostGISConnection.jav
a:179)
 at
a:570)
 at
com.vividsolutions.jump.workbench.ui.plugin.OpenProjectPlugIn.executeQuery(O
penProjectPlugIn.java:191)
 at
com.vividsolutions.jump.workbench.ui.plugin.OpenProjectPlugIn.load(OpenProje
ctPlugIn.java:178)
 at
com.vividsolutions.jump.workbench.ui.plugin.OpenProjectPlugIn.loadLayers(Ope
nProjectPlugIn.java:162)
 at
com.vividsolutions.jump.workbench.ui.plugin.OpenProjectPlugIn.run(OpenProjec
tPlugIn.java:99)
 at
com.vividsolutions.jump.workbench.ui.task.TaskMonitorManager$TaskWrapper.run
(TaskMonitorManager.java:148)
 at java.lang.Thread.run(Unknown Source)
The different between (A) and (B) is, that I save the Dataset and then I
save the Task.
When I take a look at the two Task-Files (.jmp) I see, that they
differ in the <query> row.
.. This works case (A) (Open Task):
 <data-source-query>
   <query>SELECT * FROM punkte</query>
    <data-source
class="net.refractions.postgis.PostGISDataSource">
.. This do not work case (B) (because query null="true")!
  <data-source-query>
   <query null="true" />
   <data-source
Solution (maybe):
The class PostGISSaveDataSourceQueryChooser
has a method getDataSourceQueries()
This do not work (the null in 8) is maybe wrong?):
1)  public Collection getDataSourceQueries() {
2)    StringBuffer sql = new StringBuffer();
3)    Map properties = super.getProperties();
4)
5)    //we dont need to specify the update query since the connection
6)    // will do that for us. We only need to specify the table
7)    PostGISDataSourceQuery query = new PostGISDataSourceQuery(
8)      getDataSource(), null,
(String)properties.get(PostGISDataSource.TABLE_KEY)
9)    );
10)    query.setProperties(getProperties());
11)
12)    List queries = new ArrayList();
13)    queries.add(query);
14)
15)    return(queries);
16)  }
This works (I changed null to updateQuery):
    String updateQuery =
      "SELECT * FROM " +
      (String)properties.get(PostGISDataSource.TABLE_KEY);
      getDataSource(), updateQuery,
    queries.add(query);
    return(queries);
I am a little confused, because the comment says:
Is there another solution?
Thank you for your help.
Uwe Dalluege
Hochschule fuer Angewandte Wissenschaften Hamburg
- University of Applied Sciences -
Fachbereich Geomatik
Rechenzentrum
Dipl.-Ing. Uwe Dalluege   :-)
Hebebrandstr. 1
22297 Hamburg
Tel.: +49 40 42875 - 5335 oder 5353 oder 5313
Fax:  +49 40 42875 - 5409
E-Mail: mailto:uwe.dalluege at rzcn.haw-hamburg.de
Url: http://www.haw-hamburg.de/geomatik/
