[postgis-users] postgis_restore.pl lost charset information
strk at refractions.net strk at refractions.net
Thu May 26 13:25:12 PDT 2005
>From 1.0.1 CHANGES file:
        - NEW support for custom createdb options in postgis_restore.pl
Basically you pass createdb option last.
A no-args invocation of it shows usage.
I hope you still have your dump around.
--strk;
On Thu, May 26, 2005 at 12:05:47PM +0200, Xavier Vanderstukken wrote:
> My original database was in latin1 encoding.
> I follow the procedure to dump and then restore the data in Postgis 1.0.0.
> (postgis_restore.pl lwpostgis.sql roads roads.dump)
> But the created database is in SQL_ASCII charset and I receive error in my
> application using jdbc to retrieve data :
> org.postgresql.util.PSQLException: Invalid character data was found.  This
> is most likely caused by stored data containing characters that are invalid
> for the character set the database was created in.  The most common example
> of this is storing 8bit data in a SQL_ASCII database.
> How can I change the charset of the created database before the import
> procedure?
> _________________________________________________________________
> postgis-users mailing list
