[postgis-users] Beginner question: Incorrect SRID?
Adrian Holovaty
postgis at holovaty.com
Sun May 29 12:58:55 PDT 2005
Hello,
I've successfully imported the City of Chicago's ZIP code data into
PostgreSQL/PostGIS, but when I try to transform() it in Postgres, I get
longitude and latitude that appears to be way off. I suspect I'm importing it
using the wrong SRID, but I'm not sure. I'm a beginner and would appreciate
some help.
The Chicago GIS Web site from which I got the data (http://tinyurl.com/7qwad)
says it follows the following standards:
Datum: NAD 83
Projection: State Plane Illinois East
FIPS Zone: 1201
Units: US Foot
Precision: 1:10,000 (1:1,000 is acceptable for most uses)
I've used shp2pgsql to import the data with SRID 26971, which looks correct to
my inexperienced eyes:
mapdatabase=# select * from spatial_ref_sys where srid=26971;
26971 | EPSG | 26971 | PROJCS["NAD83 / Illinois East",
GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",36.66666666666666],PARAMETER["central_meridian",-88.33333333333333],PARAMETER["scale_factor",0.999975],PARAMETER["false_easting",300000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26971"]]
| +proj=tmerc +lat_0=36.66666666666666 +lon_0=-88.33333333333333 +k=0.999975
+x_0=300000 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs
Here's the import command I used:
shp2pgsql -s 26971 Zipcodes.shp testtable > zipcodes.sql
Is this the correct SRID for this data? Do I have to do something special
because the data standard uses "US Foot" as its units?
Raw data, in shapefile format, is here:
http://egov.cityofchicago.org/webportal/COCWebPortal/COC_ATTACH/zipcodes.zip
The query I'm running on the data to get longitude/latitude is:
select zip, asText(transform(the_geom, 4326)) from testtable limit 1;
That query returns:
MULTIPOLYGON(((-75.3136373094386 53.5032244406271,-75.3116700756851
53.5029863825251 ...
...which corresponds to longitude and latitude somewhere in Canada instead of
Chicago.
Thanks for any help.
Adrian
