[postgis-users] how to define an alias for && operator?
Jean-Pierre Quirion
jpquirion at yahoo.ca
Fri Nov 4 08:03:05 PST 2005
--- Mark Cave-Ayland <m.cave-ayland at webbased.co.uk> a écrit :
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Jean-Pierre Quirion
> > Sent: 04 November 2005 15:14
> > To: PostGIS Users Discussion
> > Subject: RE: [postgis-users] how to define an alias for && operator?
> (cut)
> > The "OPERATOR 3 <<< RECHECK," line has been added. And this
> > does not work. Apparently you can not reuse a
> > strategy_number, is this right (3 in this case). [My
> > assumptions are based on
> > http://www.postgresql.org/docs/8.0/interactive/sql-createopclass.html]
> > Our problem is not the operator (it works), but the
> > association with an index aka operator class. If we used a
> > new strategy number like 13, we would have to define a new
> > strategy in "lwgeom_gist.c" . I am looking for an easier solution.
> > Jean-Pierre
> Hi Jean-Pierre,
> The operator classes are defined in terms of strategy number so you will be
> unable to do this. The actual modifications in lwgeom_gist.c shouldn't be
> that bad though - you could probably get away with just defining a new
> strategy around line 78, e.g.
> #define RTNewOverlapStrategyNumber 13
> And then simply replace the two occurences of "case
> RTOverlapStrategyNumber:" with
> case RTOverlapStrategyNumber:
> case RTNewOverlapStrategyNumber:
> You should then be able to add your operator by including the following line
> in your operator class:
> "OPERATOR 13 <<< RECHECK"
> Kind regards,
> Mark.
Mark,
Thanks for the hint. If we modified lwgeom_gist.c or any other file, updates of PostGis would be
less straight forward.
We found - some minutes ago- the following solution for our original problem (avoiding && in a
query).
You probably know that geometry_overlap() does not use the indexes but "&&" does. So we just
define a new function called "ampamp":
CREATE function ampamp(geometry,geometry) returns boolean as 'select $1 && $2' language sql;
The function ampamp() is as serviceable as geometry_overlap() but uses the same indexes as "&&"
does.
Do you see any inconveniences? What is the reason that postgis does not include indexed versions
of the functions? Maybe nobodies uses the function instead of the operators.
Kind Regards
Jean-Pierre
__________________________________________________________
Lèche-vitrine ou lèche-écran ?
magasinage.yahoo.ca
