[postgis-users] Error in SPATIAL_REF_SYS table
Bart van den Eijnden
BEN at Syncera-ITSolutions.NL
Wed Nov 9 00:39:03 PST 2005
You could give this a try (srid and srtext from EPSG database):
http://postgis.refractions.net/pipermail/postgis-users/2005-November/009848.html
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> kobben at itc.nl 11/09/05 8:59 AM >>>
Hi there,
I just started using PostGIS instead of the Spatial Extensions of MySQL, mainly because of the lack of SRID support in the latter. Everything went nicely until yesterday, when I found that there's an error in the SPATIAL_REF_SYS table for the Dutch National Grid. This, officialy called "RijksDriehoeksstelsel" is defined with Projection = Oblique Stereographic. But it should be Double Stereographic...
All the other coordinates seem right, but the result is still an offset of about 2 meters when combined with properly projected data....
Any ideas on how this could be remedied, or should I file a bug report?
____________________________
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
