[postgis-users] Shifted Dataset
Marco Vieira
marco_vieira at uk2.net
Wed Nov 9 09:21:47 PST 2005
Beyond projection issues, these data probably cannot be repaired with
simple action of movement. Depending on the precision criteria it is
necessary to fit the data under a adjustment computing (least squares
method for example) using many control points. Normally a street geocoding
process demands decametric precision.
Its a good idea search for a good database in another source.
Marco Vieira.
Fone: + 55 21 9499-6800
> Maik Trömel wrote:
>> Hello together,
>> i've got a problem with a vector-point dataset. The Problem ist that
>> they are shifted to east and south about 12 miles. Is it possible to
>> "repair" this shift with PostGIS?
> You might want to make sure that this is not due to a projection issue
> before you start moving the points.
> -Steve
> postgis-users mailing list
