[postgis-users] trouble with moving data
Sears, Jeremy
Jeremy.Sears at CCRS.NRCan.gc.ca
Wed Nov 16 09:47:17 PST 2005
Phew! ....
Im glad to hear that my data should look the way they do now in the updated
database.
Many Thanks to both of you!
Jeremy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Mark
Cave-Ayland
Sent: November 16, 2005 12:16 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] trouble with moving data
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Sears, Jeremy
> Sent: 16 November 2005 17:02
> Mark,
> Ive managed to get data into the database. All seemed to go
> well, I can connect to the new db via QuantumGIS and view the
> data without problem. However, my geometry column is messed
> up. In the old db the column contained regular looking
> entries, in the new db I have what appears to be binary or
> hex entries, this is an example of what the geom_col contains :
> 010600002040A50000010000000103000000020000005B020000000000602F
> 1224C1000000A0
> F4F9294100000060691224C1000000E0FDF92941000000A0721224C1000000
> E0C3F929410000
> 00A0AC1224C100000020CDF92941000000A0E61224C100000060D6F9294100
> 000060DD1224C1
> 0000006010FA294100000060171324C1000000A019FA29 ... and on ..
> This seems highly abnormal. Any Ideas?
> Many Thanks
> Jeremy
Hi Jeremy,
Don't worry this is normal with PostGIS 1.0. The reason this was changed to
an encoded format was because we had complaints from users loading and
restoring dumps that the points would move after the restore because of the
lossiness of conversion from floating point -> text -> back to floating
point.
If you want to see the EWKT(PostGIS enhanced) or WKT(OGC compliant)
representations simply do:
SELECT AsEWKT(geom) FROM geom_table
Or SELECT AsText(geom) FROM geom_table
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
