alex bodnaru wrote: > if you have postgresql-common installed, i might send you the packages > later. I appreciate your help, but I think you are working in unstable with libstdc++ 4.02 and I'm in Breezy with libstdc++4.01. If Blair can fix his pkg then that gives Breezy users both postgresql 8.1 & postgis.
