[postgis-users] Input on upgrade to GIS database
Gregory S. Williamson
gsw at globexplorer.com
Thu Nov 17 14:30:15 PST 2005
Onyx --
This really ought to be FAQ -- the geometry is ok, it's just that postGIS has changed the way it displayes when you ask for the unadulterated contents of a geometry column.
Try using asEWKT(the_geom) and you'll see it displayed with the SRID; use WKT to see it without the SRID.
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Onyx
Sent: Thu 11/17/2005 2:06 PM
To: 'PostGIS Users Discussion'
Cc:
Subject: RE: [postgis-users] Input on upgrade to GIS database
Daniel Faivre, Jeremy Sears, Darren Houston, thank you for your input. OK,
so, with your help, I have been able to bring up _most_ of our data
successfully in the new database. But, I am having problems with the data
contained within the tables of type PostGIS geometry.
Originally, the table contained something like:
SRID=4326;MULTIPOLYGON(((-105.499999977881 40.5 0,-105.499999977881
40.9999999185093 0,-105.000000006985 40.9999999185093 0,-105.000000006985
40.5 0,-105.249999999884 40.5 0,-105.499999977881 40.5 0)))
Now, after the upgrade and xfer of data, the table contains:
01060000A0E61000000100000001030000800100000006000000FA3FE8FFFF5F5AC000000000
004044400000000000000000FA3FE8FFFF5F5AC0040051FFFF7F444000000000000000000680
070000405AC0040051FFFF7F444000000000000000000680070000405AC00000000000404440
00000000000000001DE0FFFFFF4F5AC000000000004044400000000000000000FA3FE8FFFF5F
Any ideas why and how to fix?
- Onyx
Onyx Mueller
Software Engineer
i-cubed : information integration & imaging LLC
201 Linden Street : Third Floor
Fort Collins, CO 80524
970-482-4400 voice
970-482-4499 fax
http://www.i3.com
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Darren Houston
> Sent: Thursday, November 17, 2005 12:20 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Input on upgrade to GIS database
> Hello Onyx,
> If like me and you don't have custom functions, schema, etc.
> and only have a couple of tables with data, I found the
> easiest way to do an upgrade is to dump the tables, upgrade
> your database, and load the tables. I also dump and load the
> geometry_columns table and then run fix_geometry_columns(). I
> always use a new spatial_ref_sys table from the upgrade.
> VACUUM ANALYZE and you should be good to go. I keep the old
> database kicking around just in case I need to start it up
> again to grab something I forgot. I hear postgis_restore.pl
> works, but I haven't used it.
> Darren H.
> On Thursday 17 November 2005 09:37, Sears, Jeremy wrote:
> > Onyx,
> > I have recently preformed a simmilar task. In the name of
> > experimentation I had tried a coupla methods to move data from an
> > older PostgreSQL(8.0.2) + PostGIS install to a new one
> (postgresql 8.1
> > and postgis 1.0.4). The older database dumped data into a
> sql loader
> > file. This was then loaded into the new database via 'psql -f
> > datafile.sql'. This method seems to have worked although I
> did notice a couple of errors fly by as the data loaded. . .
> > Note that the new database is still in the testing phase and errors
> > could exist that I havent noticed yet.. however so far so good.
> > Jeremy
> > [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> > Onyx
> > Sent: November 17, 2005 11:01 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Input on upgrade to GIS database
> > PostGIS Friends,
> > I need some help/input on the proper approach to upgrading on
> > GIS-driven database backend, and I am hoping that some of you have
> > been in similar situations. We run a PostgreSQL database
> with Proj,
> > Geos, and (of course) PostGIS libraries. I want to upgrade
> the following:
> > - PostgreSQL 7.4.6 --> 8.1.0
> > - Geos 2.1.0 --> 2.1.4
> > - PostGIS 0.9.0 --> 1.0.4
> > What is the proper approach to get this done successfully,
> keeping our
> > existing data intact? I know that it is not as simple as
> 1) dumping
> > the schema & data from the database to a file, 2) moving/deleting
> > PostgreSQL
> > 7.4.6 (and old libraries), 3) installing PostgreSQL 8.1.0
> (and the new
> > libraries), and 4) feeding the schema & data back in,
> although I wish
> > it were that easy. I have read the section of the PostGIS
> manual on
> > upgrading, but I am worried that there are some other
> aspects I need
> > to know since I have other variables I am upgrading as well
> > (PostgreSQL & Geos). Has anyone been in my boat before?
> > Any help would be greatly appreciated. Thanks!
> > - Onyx
> > Onyx Mueller
> > Software Engineer
> > 970-482-4400 voice
> > 970-482-4499 fax
> > <http://www.i3.com> http://www.i3.com
> postgis-users mailing list
!DSPAM:437cf8f862501835115090!
