[postgis-users] Input on upgrade to GIS database
strk at refractions.net strk at refractions.net
Thu Nov 17 14:55:52 PST 2005
On Thu, Nov 17, 2005 at 11:37:58AM -0500, Sears, Jeremy wrote:
> Onyx,
> I have recently preformed a simmilar task. In the name of experimentation I
> had tried a coupla methods to move data from an older PostgreSQL(8.0.2) +
> PostGIS install to a new one (postgresql 8.1 and postgis 1.0.4). The older
> database dumped data into a sql loader file. This was then loaded into the
> new database via 'psql -f datafile.sql'. This method seems to have worked
> although I did notice a couple of errors fly by as the data loaded. . . Note
> that the new database is still in the testing phase and errors could exist
> that I havent noticed yet.. however so far so good.
Ehmm... I'm afraid those errors were important.
What does SELECT postgis_full_version() tell you ?
--strk;
> Jeremy
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Onyx
> Sent: November 17, 2005 11:01 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Input on upgrade to GIS database
> PostGIS Friends,
> I need some help/input on the proper approach to upgrading on GIS-driven
> database backend, and I am hoping that some of you have been in similar
> situations.  We run a PostgreSQL database with Proj, Geos, and (of course)
> PostGIS libraries.  I want to upgrade the following:
> - PostgreSQL 7.4.6      --> 8.1.0
> - Geos 2.1.0            --> 2.1.4
> - PostGIS 0.9.0         --> 1.0.4
> What is the proper approach to get this done successfully, keeping our
> existing data intact?  I know that it is not as simple as 1) dumping the
> schema & data from the database to a file, 2) moving/deleting PostgreSQL
> 7.4.6 (and old libraries), 3) installing PostgreSQL 8.1.0 (and the new
> libraries), and 4) feeding the schema & data back in, although I wish it
> were that easy.  I have read the section of the PostGIS manual on upgrading,
> but I am worried that there are some other aspects I need to know since I
> have other variables I am upgrading as well (PostgreSQL & Geos).  Has anyone
> been in my boat before?
> Any help would be greatly appreciated.  Thanks!
> - Onyx
> Onyx Mueller
> Software Engineer
> i-cubed : information integration & imaging LLC
> 201 Linden Street : Third Floor
> Fort Collins, CO  80524
> 970-482-4400 voice
> 970-482-4499 fax
>  <http://www.i3.com> http://www.i3.com
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
