[postgis-users] Breezy 8.1 pkgs error
    Blair Zajac
    blair at orcaware.com
    Thu Nov 17 22:16:08 PST 2005
I've rolled out a new version of the package with the fix.
You'll also want to install the postgresql-common package from my mini-distribution.
Regards,
Blair
Blair Zajac wrote:
> I'll roll out a new version of the package with this change tonight.
> In the mean time if you don't want to compile postgresql, just don't
> install postgresql-server-dev-8.1 :)
> Regards,
> Blair
> alex bodnaru wrote:
>> please do the following:
>> download the and unpack postgresql-8.1 source packages.
>> edit debian/postgresql-server-dev-8.1.install, and remove the first and
>> last line.
>> rebuild and install the package.
>> good luck,
>> alex
>> John Taber wrote:
>>> I tried to install Blair Zajac's pkgs but get error installing
>>> "trying to overwrite '/usr/share/locale/cs/LC_MESSAGES/pg_config-8.1.mo'
>>> which is also in package libqp-dev
>>> dpkg-deb: subprocess paste killed by signal (Broken Pipe)
