[postgis-users] Query crashed
Stephen Woodbridge woodbri at swoodbridge.com
Sat Nov 19 16:38:51 PST 2005
Paul,
Thank you for the help and suggestions. max_distance() sounds like a
good way around the crash problem, but I get ...
canada=# select count(*)
canada-# from
canada-#   roadseg r, streets s
canada-# where
canada-#   expand(r.the_geom, 0.00007) && s.the_geom and
canada-#   max_distance(s.the_geom, r.the_geom) < 0.00007;
NOTICE:  LWGEOM_gist_joinsel called with arguments that are not column
references
ERROR:  This function is unimplemented yet
I have the function defined in my database as:
CREATE OR REPLACE FUNCTION max_distance(geometry, geometry)
   RETURNS float8 AS
'/usr/local/lib/liblwgeom.so.1', 'LWGEOM_maxdistance2d_linestring'
   LANGUAGE 'c' IMMUTABLE STRICT;
ALTER FUNCTION max_distance(geometry, geometry) OWNER TO pgsql;
-Steve
Paul Ramsey wrote:
> Just realized, there is a max_distance() function in PostGIS, so you
> can make replace the within(buffer()) call with something much faster
> that is almost semantically equivalent:
> select count(*)
> from
> where
> The semantics of max_distance are here:
> <http://postgis.refractions.net/pipermail/postgis-users/2002-January/
> 000554.html>
> P.
> On 19-Nov-05, at 2:29 PM, Paul Ramsey wrote:
>> Well, you crashed the backend... probably with the buffer(), though
>> the gist_joinsel error is oddball.  Oh, your GEOS is quite over a
>> year old and a lot of bugs have been scrubbed since then, so an
>> upgrade there would help in general.
>> Finally, your query syntax is hell, here is why:
>> buffer(foo) && somethingelse
>>   you are doing an incredibly expensive geometry operation (buffer ())
>> and then only comparing the bounding box!  use expand() instead
>> within(something,buffer(foo))
>>   well, I see what you are doing here, and there is currently no
>> other way. you are looking for items which are "mostly equal" to
>> other items.  that is, they may have had some coordinate drift do  to
>> rounding errors, or been noded in places, or had some vertices  added
>> or removed, but they basically describe the same line on the  ground.
>> what is really needed is a kindaequals (geom_a,geom_b,tolerance)
>> function that returns a number of values,  depending on the equality
>> case: 1 = completely equal, 2 = describe  the same line within
>> tolerance, 3 = geom_a is same as geom_b but  shorter, 4 = geom_b is
>> same as geom_a but shorter.
>> P.
>> On 19-Nov-05, at 1:56 PM, Stephen Woodbridge wrote:
>>> Hi all,
>>> I was running the following query:
>>> select count(*)
>>> from
>>> where
>>>   buffer(r.the_geom, 0.00007) && s.the_geom and
>>>   within(s.the_geom, buffer(r.the_geom, 0.00007));
>>> And it crashed with the following error message after running for
>>> 1,959,844 ms in pgadmin3:
>>> column references
>>> server closed the connection unexpectedly
>>>     This probably means the server terminated abnormally
>>>     before or while processing the request.
>>> The "roadseg" table is the geobase roadseg data for all provinces
>>> loaded into a table and the "streets" is the same for the Census
>>> streets data for all provinces.
>>> postgis_full_version() reports:
>>> POSTGIS="1.0.4"
>>> GEOS="2.0.1"
>>> PROJ="Rel. 4.4.9, 29 Oct 2004"
>>> USE_STATS DBPROC="0.3.0"
>>> RELPROC="0.3.0"
>>> and version() reports:
>>> "PostgreSQL 8.0.4 on i386-portbld-freebsd5.3, compiled by GCC cc
>>> (GCC) 3.4.2 [FreeBSD] 20040728"
>>> Any ideas on what this is about. All the data was loaded via  shp2pgsql.
>>> Thanks,
>>>   -Steve
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
